Coilovers worth my time?
Scuba_Steve
Whats up guys? I'm lookin to drop my '07 ASM TLS. I was originally thinkin about goin with a spring and shock combo. Possibly tein stech and tokico shocks, or maybe h&r sport springs and tokico shocks. Now I am thinkin about goin with coilovers because I live in Chicago, so I gotta deal with the wonderful snowy winters!
So I like the ability to be able to raise it back up with the coils for winter. I was thinkin possibly TEIN SS. Also have heard good things about Megans. I have experience with doin drops with springs and shocks, but coilovers would be a whole new ballpark for me! I'm gonna be doin the drop and throwin on some 19s in the spring. I'm lookin for as good a ride quality as possible. I know its gonna be more stiff than stock though. So would it really be worth my time to go with coilovers? I appreciate any help and advice that u guys can give!
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
AZ Community Team
Received 7,770 Likes
No difference.
Takes basically the same amount of time and is the same work to do springs, springs/shocks and Coil-Overs.
Only difference with Coil-Overs, you don't need to compress/remove/replace the spring, so the Coil-Overs should actaully be easier.
Find out if you need to re-use the OE Top Hats or not. I think a few guys went and bought new Top Hat parts so their Coil Overs were "plug & play".
Check the DIY/Service Manual scans.
Regardless (springs/shocks or Coil-Overs), dampening adjustments (espcially the rear) and/or Ride Height adjustments are a PITA.
if you adjust ride height, you will have to get alignments done everytime you change height.
On regards to Megan Coilovers, I have heard negative things in regards to their build quality.
At least you know ride quality will be stiffer. What type of drop are you thinking? I know Tokico HP (blue) are designed for 1.5 or less of a drop. If you want Eipach then the Eibach/koni setup is ideal.
Scuba_Steve
Former Sponsor
So I like the ability to be able to raise it back up with the coils for winter. I was thinkin possibly TEIN SS. Also have heard good things about Megans. I have experience with doin drops with springs and shocks, but coilovers would be a whole new ballpark for me! I'm gonna be doin the drop and throwin on some 19s in the spring. I'm lookin for as good a ride quality as possible. I know its gonna be more stiff than stock though. So would it really be worth my time to go with coilovers? I appreciate any help and advice that u guys can give! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
If you need a quote let us know.
Illist
i say coilovers...... ive personally been through alot of Combos in my past cars, and nothing beats full adjustability.
On a side note, i have had Megan Coilovers on 3 different cars.(currently running megans on my TL-S) and they been Good as far as reliablity and build quality in my opinon was equal to Tein. Megans also come with Pillow ball mounts, u dont have to reuse stock tophats like u do with Tein SS and Basic setups. plus ride height and spring preload are independent from each other. when slamming Tein ss or Basic setups u have to wind the collars all the way down, which makes the spring loose and may start rubbing against threading. fully independent system you wont have to worry about that.
Coilovers FTW
Coilovers FTW
Tein SS can be adjusted to ride even softer than stock- or a little stiffer for a basic nice ride with better handling- or up to race track stiff- all with the simple turn of a t-handle allen wrench you put in the very top of the shock
I play with the front adjustmet way more often than the rears, and you can always cut an access hole to adjust the rears!
or get the edfc controller and electric motors will adjust the shocks as you drive- on demand
Normal adjust procedure- pull over- put car in park- open hood- click click click- do other side the same- close hood- resume drive and feel differance.
My wife loves that feature!!! The road gets suddenly rough--say, miles of road construction lay ahead---making the car bouncy- ````make it better!``` she says
Yes dear!!!!
Yes dear!!!!
1fatcrxnem1
22
06-01-2018 01:23 AM
asahrts
09-04-2015 05:55 PM
