clueless on offsets
Old Jun 13, 2008 | 12:48 PM
rex1's Avatar
clueless on offsets
Okay guys I have found some wheels that I really love but I am unsure if they will fit or not on a six speed. Thay are gram light 57f bronze 18x8.5 with a offset of 45. Now to be honest I am clueless when it comes to offsets on wheels. Does anyone know if these will fit.
Old Jun 13, 2008 | 12:54 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
I think you're gonna need a 35mm offset... cause of that little lip on the wheel..
Good Luck... best thing to do is TEST FIT..
Old Jun 14, 2008 | 12:21 AM
Bike Effects's Avatar
2 TL Owner
Can someone tell me what the offset number refers to?
Old Jun 15, 2008 | 12:21 AM
Fulani has a TL's Avatar
"The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle."
Calculator: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jun 15, 2008 | 08:57 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
those wheels fit perfect...
on an 8.5 wheel you want to stay in between +35 and 45
with an 8 wheel you want to stay in between +32 and +45
Old Jun 15, 2008 | 09:44 PM
2 TL Owner
Thank you. I assume that measurement is in millimeters?
Old Jun 15, 2008 | 10:49 PM
Yup they're in millimeters
Old Jun 16, 2008 | 12:19 AM
rex1's Avatar
So they will fit? How do you guys think they will look on my wdp? I know they are only 18s but I am just as conserned about performance as I am looks and these are about 16 pounds. I am also dropped about two inches on teins.
Old Jun 17, 2008 | 05:44 PM
night2's Avatar
5th Gear
ok im the same way when it comes to offsets and ive been searching threads for the past few days tryin to find an answer to my question. i just want to know will and 18x9 with a +38mm offset fit under an 04 TL with no mods to suspension?
Old Jun 18, 2008 | 09:07 AM
rodneyc77's Avatar
yes
Old Jun 20, 2008 | 12:28 PM
rex1's Avatar
So I guess no one has an idea on how these would look on my wdp. I would try to post a picture but I am a computer idiot
Old Jun 20, 2008 | 12:58 PM
TeknoKing's Avatar
Those measurements will clear brembos?
Old Jun 24, 2008 | 07:36 AM
BLACKDOUT05's Avatar
Headlights
Does any one know anything about taking apart headlights to paint the markers? I know they are sealed any ideas on taking them apart?
Old Jun 24, 2008 | 09:17 AM
94 DC4 RS LSV/Turbo
nope you know the brembo brakes are an entirely different beast
Old Jun 24, 2008 | 09:31 AM
DIRTYSOUTH_TYPE-S's Avatar
03 TL-S
"Search" my friend
Old Jun 24, 2008 | 10:46 AM
ndabunka's Avatar
'06 750Li Sapphire/Creme
Brembo fitments depend on the style of the wheel. Some may, some may not with those stated offsets.
Old Jun 24, 2008 | 10:50 AM
ndabunka's Avatar
Rodney - I think you got it backwards. The further in the offset, the larger the lip can be and still remain tucked under the wheel well. +45's are further in. The +35's would be further out. Further out/away yeilds less room for any "lip".
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Acura604
Oct 7, 2015 06:08 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
