Camber wear
Camber wear
What would be a good camber kit if im drop on tein s-tech with a 1.3 drop in the font n 1.2 in the rear. With 18 inch aspec wheels. All comments are welcome.Thanks
with a minor drop like that i don't really think you require a rear camber kit...
but i suppose it doesn't hurt to get one to be on the safe side. if that's the case i would recommend Ingalls
http://www.heeltoeauto.com/Ingalls-C...-pr-50003.html
or
http://store.excelerateperformance.c...5/i-60220.aspx
you will need 2. One for the rear left, one for the rear right, total price should be ~$150
or
Generally you shouldn't need a camber kit with that drop but it depends on the car.
I'd drop it then get the alignment checked after a week or so ..
I had near the same drop and 18s and I needed a kit because the camber was too far off stock.
Received 6,470 Likes
Turbo speaks the truth (he always does!). I lowered on H&R Sports Springs, didn't have to get a rear camber kit. But I got an Eibach Kit-just to be on the safe side.
I have the exact same set-up, TEIN S-Tech springs with A-Specs.
I didn't NEED the rear camber kit, but I drive a lot, so I got one anyways. A camber kit is cheaper than a new set of tires
thanks alot everyone all your help is well needed. i made my mind im planning to order the ingall rear camber next weekend after i get a alignment. thanks my fellow acurazine family
hey CLtotheTL32. what rear camber kit do you have?
Former Sponsor
Just about every lowered 3rd gen TL needs a rear camber/toe kit. I'd recommend the INGALLS kit; it includes two arms in a kit (one for toe and one for camber). You need a qty of 2 to complete the rear of the car.
Said it many times, why would someone spend the money for wheels, tires and suspension components and not spend the paltry $160 foe the camber/toe kits, then there is no question when the car is aligned.
Good price BTW!
I have the Ingalls rear kit.
Camber doesn’t matter as long as it remains within specs. Some TL's with OE suspension are at the camber limits and when the car is lowered, even slightly, the camber is out of spec. Others may be at the low end and when lowered they will still remain within spec. As I said earlier, each car is different and only an alignment will determine if a kit is needed, or install one beforehand and then there will be no doubt that the car can be aligned properly and no irregular tire will be noticed.
Former Sponsor
Glad you took the time to clear that up!
Yea, I guess this old guy isn't up with the times as I thought it said WEIRD!
As I can't retract my reply, an apology is definitely required, so sorry for the misinterpretation.
Guess I had better take a break for a while.
emailnatec
29
09-28-2018 04:27 PM
