Camber issues---Not to Worry!
I had virtually the same issue. In fact I still haven't done anything to correct my SLIGHTLY negative camber in the rear. Don't go buying "spacers" (Technically, they're called shims) Even if they're only ~$20. Here's the deal....
Rear Shim kits come with 2 sets of shims and longer bolts. Each set is for one side. The reason for two shims in each set is that it gives you the option of using a thicker or thinner shim (or both if your camber is really bad) depending on how bad your camber is. Typically, the set consists of one shim that is .125" thick and one .188" thick. The guy who aligned my car said that all I needed on one side was one .188" thick shim and the .125" on the other side taht wasn't so bad. He also said that I wouldn't necessarily have to change the bolts because it's not urged unless you exceed .312", or both shims stacked. So after talking to the guy a little longer it dawned on me to go to Home Depot, Lowes or another place that sells hardware and simply buy large washers that were .125" and .188" thick. Then all I would have to do is "sandwich" each of them between the suspension arm and the frame of the car around the bolts, keeping in mind that the side with slightly worse camber would need the slightly thicker washer. Actually, I plan on doing mine this weekend.
PROBLEM SOLVED FOR UNDER $3.00 ! Good luck!
Conteez
Conteez
emailnatec
29
09-28-2018 04:27 PM
