Camber Issues
Old 04-22-2015 | 09:21 AM
amorri19's Avatar
Camber Issues
A couple weeks ago I installed some Tein H-Tech Lowering Springs on my 06 TL and now the tires are cambered pretty hard. The guy at the tire shop told me that there wasn't enough adjustment room on the OEM control arm to pull the wheels back in. When I looked online I found control arms anywhere from $80-$160. Has anyone had this issue and been able to fix the problem without spending a fortune?
Old 04-22-2015 | 10:13 AM
Put original springs back on
If you want to fix your camber properly, then get a camber kit from one of our vendors
Old 04-22-2015 | 10:24 AM
show us your alignment sheet specs and we'll be able to show you where you can adjust and what causes tire wear.
toe causes tire wear.
the spec for rear camber is up -1.7 degrees.
I lowered my car pretty low and camber is still in spec.
but toe wasnt.
I had toe zereod out and all is good
james357
02-13-2016 02:37 PM
o8 ENVII 8o
11-30-2015 04:23 PM
Robospinner
22
09-24-2015 08:47 AM
funkbro2
09-21-2015 07:53 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Camber Issues
