Bumper Tab Removal - Headlight Bracket Question
I really doubt the headlight bracket is rubbing your wheels. its the metal tab in question.
these kinds of questions are case by case basis, as your set up is VERY different than mine!
shave a little bit off, then test fit. if still rubs, keep grinding away at metal tab. then test fit. still rubs? keep grinding.
thats the only way you will find out!! !
plus, if you grind away the bracket, how is the head light going to attach?
Since the metal tab and the headlight bracket intersect at the same point, should I just deal with the metal tab and leave the headlight bracket as is? I know the headlights are bolted on via a few front bolts, but didn't want to cut more than I have to.
yeah, the headlight bracket shouldn't be a problem, only that metal tab piece - i grinded mine down with a dremel, as I was having the same issues of it like peeling my tires, grinded down no more tires issues...
