Bridgestone Potenza RE760?
I know Summer is far away, Winter is just here. But I need to know about these particular tires. I understand they have quite the grip for an inexpensive set of summer tires, but need to know if anyone experienced these tires on any car at all, doesn't matter if its not a TL. If so, how has your experience been?
I will be ordering them in advance to get a good deal right away. I am planning to go for 255/45/18 all around, wide but good enough for 18x8.5 A-Specs right? I don't want curb rash trouble so I heard wider tire helps to avoid it in certain ways...
I am done with low-profile tires, cannot stand the ride discomfort even at this age. I am lowered on TEIN Basics (factory recommended setup) during the summer. Let me know your opinions or if you know anything about these tires. I have gone through some reviews and everything seemed positive. Are these tires better than Falken 452's? I basically want a much more comfortable and stable setup with good grip and good longevity. Recommend any other summer setup that will go for under $1000 (set of 4) as well.
Food For Thought:
Just looked up the 760 and in the 255/45-18 size the load rating is 99, pretty hefty tire, so big is not always better. The son in law put some 265/65-17 on their Grand Cherokee, ride is horrible and when it encounters a sharp ridge in the road the rear will actually lift off the ground, no give. The original Jeep tires were 103 and the replacements are 110, just to give you an example. Look for a tire with the standard load range 93, not an XL. Even the 245/40-18 760 is a 97 XL, stiff tire.
Examine the tire before purchase and you'll be able to see the carcass resistance by trying to push inward on the tread while the tire is standing upright, naturally unmounted. Some will give slightly while others are stiff and afford no movement.
is in Honda heaven
1 Post
I've got the RE750 which I would think is very similar just a little older and they were great for the summer. They're very sticky and worked great in the rain as well. Here's a pic of mine
I'm still of the opinion that a good quality UHP All Season is the way to go for us up here. The Yoko Avid W4S that I had was a great tire and their replacement the Envigor W looks interesting. UHP AS tires offers more than enough grip for these cars for 99% of driving, they wear longer than a max Summer tire and you can run them until first snowfall and they won't turn into hockey pucks below -5C.
I was thinking about the RE760s as my next set of Summer tires (before I got rid of my TL-S) as the local Costco has great pricing on them. A fellow co-worker has them on his TSX, he loves them (great in the wet) but said that they do wear out very quickly...he's a fairly spirited driver.
I suppose I will have to research on the load rating and other specs of these tires to understand their characteristics. Nonetheless, I saw this tirerack comparison and it seems they rated the Potenza RE760's at 4th place while the Michelin PS2 and Dunlops lead the rest.
http://www.caranddriver.com/reviews/...0_sport_page_8
wow looks almost like slick tires...similar prices compared to the Bridgestones. My question is, I currently have 235/40/18 falken tires and the ride was terrible, every bumps and potholes were noticeable. It wasn't comfortable at all, I am thinking whether it was because of the sidewall aspect ratio being lower than stock which is 45.
Or maybe it was because I was riding on 18" compared to 17". I am not sure what it was. So do you think the 40 sidewall ratio will still be as uncomfortable as my falkens? My winter setup on the stock 17 inch rims is so much more comfortable, not sure whether its because of 17 inch rims or the 235/45 tire size.
If you stick with the 40 series but do a 255, your tire will be taller. A 40 series means the sidewall is 40% as tall as the width of the tread so going wider with the same aspect ratio will also give you a taller tire.
The factory 17" tires were a 235/45/17 while the OEM a-spec 18s were a 235/40/18.
Tire construction and type will play a large roll in how it feels. Almost as much as the sidewall will.
The NT05 tire has a very compliant sidewall for the amazing turn-in crispness and response but it's still fairly stiff.
That's one big advantage of a tire with very large treadblocks toward the shoulder.... The sidewall does not have to be as stiff to get the same cornering response.
Thanks for all the info, got a good quoted offer for these tires in Canada, apparently they have a clearance sale, might just grab them right away. The Potenzas are cheaper but these Nittos seem to have a better rep. for good handling and overall a good bang for the buck.
Quoted Price:
235/40ZR18 $248
245/40ZR18 $259
Do you recommend having 225/235 at front and 245 in the rears or should it be the same pattern all around? There seems to be no 255/40/18s on any of the online tire stores. Are the NT05's good on the rain as well?
Quoted Price:
235/40ZR18 $248
245/40ZR18 $259
Quoted Price:
235/40ZR18 $248
245/40ZR18 $259
Quoted Price:
235/40ZR18 $248
245/40ZR18 $259
Those prices don't look that good but I know everything is more expensive in Canada. Originally I got mine for $850 for a set of 4 online. I found a place hurting for business that will give me a set of 4 for $650 out the door mounted, balanced, and taxes. Tire shops have a lot of room for bargaining if you have the time to do it.
You definately want the same size all around. Don't worry too much about the narrower size. These tires have the highest tread to void area of any tire out there so you will still have a ton of rubber on the ground. Besides, the compound is more important than the width.
I don't recommend these in the snow at all. There's probably nothing worse out there for the snow.
They also only come with 6/32nd tread. I've managed to get over 20,000 miles out of them but I've read where some people get 10,000. I can also run them to a lower tread depth because it hardly ever rains around here.
The only real competition in the same price range is the Direzza Star Spec tires. From what I've read they're very good tires but most people who have run both usually give the nod to the NT05.
Thanks again, I come to NJ/Philly area every now and then, will be visiting this December so might as well pick these tires up from the store that can give them for $650. Is it located anywhere in the East Coast or is it somewhere else? I will be going for 245/40/18.
The place I get them from is on the West Coast. I can see if they would be willing to give the same deal to you. They're basically giving me the wholesale price. Not sure what shipping would be like though.
Chapter Leader (San Antonio)
Get the Hankook Ventus V12, best tire overall out of any tire.
I'd recommend going to Discount Tire for the tires by doing this:
Go match the price online to Discount Tire DIRECT.
Ask Discount Tire Direct about there deal with Replacement Certificates (They gave me $30 off). Get that invoice with the online match price and discount for certificates and free shipping.
Bring it to Discount Tire store and make them price match the exact same invoice (my ended up even cheaper by a few bucks) and you only pay that and the mounting and balancing which is only $64 (lifetime rotation + balancing). Found this to be the BEST method possible.
This is even a nicer comparison for the NITTO branded tires, mostly good performance ratings truthfully stated by Nitto themselves.
http://www.nittotire.com/index.html#...e.invo.compare
I am looking at the NT555 and the INVO tires for a complete comparison with NT05's. As for the Hankook tires, I already have a Hankook winter tire and not looking for another Hankook summer tire.
Just a little more on my NT05 experience...
Alignment is crucial. It's important for any tire but as you get into these soft tires, they will wear much quicker if your alignment is not perfect.
Mine were extremely quiet when new. They have a high pitched sound at about 45mph but they're as quiet as stock.
At one point my alignment was screwed up by the bodyshop. Toe was 5 degrees off. They feathered in the rear and got noisy. My fronts are nearly to the wear markers and they're still quiet. Noisier than brand new but still quiet overall.
You will get a little more noise when going over expansion joints and sharp jolts than OEM.
The turn-in is seriously as sharp as a full race tire. I've never experienced a street tire with this kind of turn-in.
When you get near the limit, they squeal just a little, letting you know you're there. The thing that's really good for the street is that when they break free, the slide is very easy to control. Many tires with this kind of grip break free abruptly and it's hard to keep control of the car.
These tires are awesome for the track. Most street tires get greasy and start losing grip from the heat generated by a heavy car like the TL. These just keep gripping and gripping.
I've had one street tire come close in braking, it was the BFG G-force KDW-2. They just about matched the NT05 in braking but they could not match the cornering and they were so noisy that I replaced them with over 50% of the tread left. They also had a very stiff sidewall.
There are tires that can beat these in a single category (but very few) but none that can match the overall package.
The only thing that makes me nervous recommending them is your climate. What's the temp like in the summer up there?
Seems like you're going polar opposite in picking your tire than what you had stated as your wants.
I've been running these since February 2010 and have been very happy with them. Even better performance than my Goodyear Eagle GS1-D3's and they are more quiet. I'd recommend them.
^If this is your criteria, the Nittos or any other tracked focused tire would be my absolute last choice as these types of tires have much stiffer sidewalls than the highest performance AS tire which are great for extreme cornering on the track (or the nice flat unbroken roads of California) but not great for comfort on the frost-heaved broken roads of Ontario. And they will turn into hockey pucks in the Spring/Fall.
One on the right for me
Little more noise than OEM tires, work well in wet/dry but are not the greatest in snow. I make plenty of trips up to Tahoe but probably not the best tires to have on the car. The tires last a long time.
So in that case, the Bridgestone RE760's are still the best option right? I know the Nitto INVO is a very comfortable set of tires for most luxury cars. I always change my tires to the winter setup as soon as it gets sort of cold around here. Basically, I am looking for a good set of tires that is comfortable yet has good grip. Michelin PS2/Bridgestone RE760 are mostly the industry standards, so what would you recommend besides these?
I know for a fact the NT05 is softer than the PS2 as any C6 Corvette owner will tell you yet it has better response and turn-in.
If comfort is really important it might be best to take a step down to a lower performance category like some performance all seasons.
As for the diameter....
Your current tires are 25.40 overall diameter
A 245/40 is 25.71"
A 255/40 is 26.03"
A 245/45 is 26.68"
A 255/45 is 27.03"
A 245/45/18 may be what you want with just over half an inch extra on the rim. This way you could pick a summer tire and get decent comfort.
My bridgeys are excellent.(760's) Great grip and very quiet. I have 0 negative things to say about them. I'm sure to get at least 40k out of them. I ride a stock setup if that matters at all to you.
You are talking about the KDW-2, right? If it's the regular KDW (which I thought they quit making), you're right, great tire. I have them on the front of the GN.
IMO...Again, I'd look at a UHP All-Season tire like a Michelin Pilot Sport AS, Continental ContiExtreme AS, Bridgestone Potenza 960AS, etc which will give you the performance that you're looking for and the comfort/longevity that you want. Seriously, unless you are tracking the car you won't even approach the limits of what a high end Max Performance Summer tire is capable of, on the street. But you'll encounter its downsides which are accelerated wear and harsh ride.
I have to go for the RE760's, have heard that these are comfortable tires even for a summer tire, so might as well try them on.
I will be going for the 245/45/18 if the 255/45/18 seem to be to tall for my lowered setup. Looking for a honest Bridgestone dealer in T.O. for now, most folks carry Michelins, Hankooks and Goodyear tires.
Thanks for the costco link, I am not a member there but I found some local authorized dealers who are asking $920 for 245/45/18 and $900 for 245/40/18. We get ripped off here in Canada, I would be able to get the same tires for less than $600 in the States.
Well my only concern with the 245/40/18 setup is the aspect ratio is smaller, meaning its more of a lower profile setup. I ran 235/40/18s and honestly, the setup I currently run just feels smoother and bumps are not felt that much. 40 would be cheaper and would look better but my instinct says it would be a lot more bumpier, how about ttribe, are your tires comfortable enough? Or is it stiffer than normal stock setup?
IMO, the comfort difference between a 245/40 and 245/45 would be negligible at best.
thank you sir! that's a pretty good deal, will be looking out for a COSTCO member now.
Installed 4/1
Had my 245/40-18's installed yesterday, April Fools Day...Bad Karma?? Anyway, they did fine on the ride home in 42 degree rainy weather. Hoping the snow in WI is done for the year.
Gotta say the 245/40 looks better than the 235/40 that came off. Not sure what it is, maybe that size just fills up the 8.5" A-Spec rims better. I will post some more info once I get some miles on them in warm weather and have a chance to push them.
