Which is better 18x8.5 or 9.5 for 3g
I will be purchasing some new wheels. i know offset matters but which is better for our 3gtl. Will a 18x 9.5 wear out the wheel bearings faster than a 18x8.5?
or is it only having an lower offset than designed for our cars which is et 45 going to wear the wheel bearings?
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Stand For Something
I have 18x9.5 +35 all around, I'm about 95% happy with it. I think I'm gonna push the rear to +30 soon. These are good specs if you do not have your fenders rolled and you don't want any rubbing. You do have to run 235 tires tho.
Depends. I'm all for putting all the rubber to the ground that you can for performance. Only thing is, are you going to be running a 265-275 to take advantage of the wider rim, probably not. 8.5 will easily accept a 255 or slighlty wider so I say go for the 8.5 as far as peformance is concerned.
rockvilleTL
09-19-2015 04:44 PM
