Best tire size for 19' wheel"(rim) for TL ???
19" Enkei Racing GTC-01 wheels Hyper Black
Offset: 42mm
Backspacing: 6.49"
Bolt Pattern: 5-114
Weight: 23.1lbs., W/235/35/19 tire 45lbs., W/245/35/19 tire 47 lbs., Stock wheels and tires 48lbs
Finish: Hyper Black
Construction: 1pc. Gravity Cast w/ MAT Technology
Can I fit 245/40/19?? will they look bad?
Offset: 42mm
Backspacing: 6.49"
Bolt Pattern: 5-114
Finish: Hyper Black
Offset: 42mm
Backspacing: 6.49"
Bolt Pattern: 5-114
Finish: Hyper Black
Offset: 42mm
Backspacing: 6.49"
Bolt Pattern: 5-114
Finish: Hyper Black
eg 235/35/19 the aspect ratio is 35 or 35% of the tread width 35% of 245 is going to give you a taller side wall.
RAR
Another FYI, with the low profile tires, you definitely want to get that insurance when you buy the tires, they are at significant more risk of blowing out if you run over something in the road.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
