Beefy Tire Setups, Show Us What You've Got!
Old Sep 13, 2016 | 05:35 PM
  #321
VisualEchos's Avatar
Andrew
Originally Posted by BiggPinyot
How did you end up in a perfect situation to get that picture? That's an awesome picture man.
Perfect situations don't really exist, they're created via witchcraft .
Old Sep 13, 2016 | 09:04 PM
  #322
BiggPinyot's Avatar
Originally Posted by Oh Sickest TL
I was kidding about slamming. lmk what the 7mm looks like
Yeah I know. Slamming is not for everyone. My car was about 10mm lower in front before and I couldn't get out of my own driveway without scrapping. No fun. LOL. When I throw the 7mm spacer on there, I will shoot a picture for you guys to see.
You Photoshopped the fog in the background? If you did, mad props bro. Your pictures are on point. And that rear tire looks crazy fat.
Old Sep 13, 2016 | 09:11 PM
  #323
Andrew
Before:
After:
The Arrival. by Andrew Thompson, on Flickr
Old Sep 14, 2016 | 09:23 AM
  #324
BiggPinyot's Avatar
My bad Harry Potter! Your wizardry is pretty good. I don't use photoshop much, so I get amazed when people can do things like that. That's awesome man. I keep my pictures pretty basic when it comes to my car. I just like to find good spots to shoot them, which is hard in my area. I need to drive like 30 to one hour to find a nice spot.
Old Sep 14, 2016 | 09:34 AM
  #325
Andrew
I do that mostly as well, but sometimes I have a concept and only witchcraft will do.
Old Sep 14, 2016 | 05:46 PM
  #326
BiggPinyot's Avatar
It's pretty cool man. I like it. I need to go out and take more photos sometime so we could add pictures on here. LOL.
Old Sep 24, 2016 | 05:34 AM
  #327
Boosejars's Avatar
Originally Posted by o4Komodo
Set up looks great. But while your rim-spec is 'beefy' I wouldn't call 245/40 beefy. You can always get wider tires like you're thinking.... and widen your fenders
Yeah - i hear that - but to me, compared to all the "stanced and dumped cars" rolling on 205, 215. and 225 series - I consider my 245 pretty beefy I couldn't imagine running 285 - sheesh, i've been contemplating going to a 255 next set of tires though - will probably have to raise slightly in the front - or just massage the fronts and pull them a bit more
Old Dec 25, 2016 | 11:29 AM
  #328
BiggPinyot's Avatar
Bringing this thread back from the dead!
I wish I could go wider on wheels and tires, but I have to wait off on that.
Old Dec 29, 2016 | 04:16 PM
  #329
rubenders's Avatar
performace tl-s
i have 255/40/17 for the past 40k and i wong get it again the car move side to side too much with this tires. sidewall flex
Old Dec 29, 2016 | 06:17 PM
  #330
^that's NOT because of the size you picked.....
what brand of tires did you choose?
and have you gotten an alignment?
Old Dec 29, 2016 | 07:11 PM
  #331
Andrew
And why exactly are you in the beefy tire thread??
Old Dec 30, 2016 | 09:08 AM
  #332
BiggPinyot's Avatar
I'm running 255/35/18 and I think it runs fine. I eventually want to go wider. I may look for 9.5-10 inch wide wheels eventually and run a 265-275 series tire. But we will see how it goes. Money will play a huge factor.
Old Mar 14, 2017 | 11:14 AM
  #333
llllBULLSEYE's Avatar
Running 265/35/19 very comfortable but so beefy it rubs at +15 offset so I had to raise the car a lot in the back
Yesterday I ordered the correct diameter tire 265/30/19 which is equal to a 265/35/18 tire.
+15mm
+35mm
old setup 225/35/19
Old Mar 14, 2017 | 11:27 AM
  #334
Andrew
Looks nice, just a bit of a stretch. 19 x 10?
Old Mar 14, 2017 | 11:58 AM
  #335
They are 19x9.5
Old Mar 14, 2017 | 04:58 PM
  #336
ATLS_666's Avatar
3 2 GONE
They are 19x9.5
Bad AF, more pics!
Old Mar 15, 2017 | 12:04 AM
  #337
evarela25's Avatar
Damn BULLSEYE that looks really good ... I wish I could run a wider tire but I'm rubbing a little already with my set up 245/40 18x9.5 +33
Old Apr 17, 2017 | 12:13 AM
  #338
UTAH Type-S's Avatar
Hey all im in desparate need of a fatter wheel and tire setup.
Im thinking 18x9.5 45 offset. I dont really want any poke if I can avoid it.
What tires do you think would be a good fit the fatter the better.
275/30/18? 285s?
Think that i would have anything poking out on a setup like that?
Also VisualEchos you got those 10.5s you mentioned last page on the car? Im curious how that works.
Any advice or input is much appreciated. Im lowered on Tein Street Advanced but willing to raise it up a bit.
Old Apr 17, 2017 | 08:59 AM
  #339
Andrew
275/30/18? 285s?
First, the magical numbers for a wide tire with perfect fitment and NO WORK are: 18 x 9.5 +45 with 255/35. End of story.
With that combo, and a the drop of your choice, you'll 99% chance have no poke, no rubbing, and no need for a roll.
The problems start when you want to go under +45, wider than 9.5", want your camber in spec, or want a wider tire. And the problems are quite diverse, so if I give you a scenario with any of the above specs changed, it's just an educated guess.
The first thing to consider with a wider tire is the OD, IMO, because a 285 will fit under the car with no problems if the offset is correct.
Stock OD: 25.5"
255/35/18 = 25"
265/35/18 = 25.3"
275/35/18 = 25.6"
285/30/18 = 25.7"
See how short the 255 is? That's your ticket to no work. Every car is a little different, so in a worst case scenario you'd have to roll the rear a tiny bit, but that's all.
You can also see why I chose a 265/35 for my car, as it's just slightly shorter than stock, making fitment just a little easier, and it's close to square on a 9.5" wheel.
Most 9.5" wheels are made +38 or +40, there are some +45, but if you have to get +38 or +40 it'll be fine, it's all in how much work you want to do to make them fit.
I still haven't made up my mind on the 10.5" wheel, my car is a daily driver, so I like being in spec @ -1.5°, but 10.5 +45 with a 285/30 @ -2.5° camber is definitely possible.
Old Apr 19, 2017 | 09:41 AM
  #340
Stock OD: 25.5"
255/35/18 = 25"
265/35/18 = 25.3"
275/35/18 = 25.6"
285/30/18 = 25.7"
so what im getting there is at those wheel specs i can get away with little to no work on a 255-35 but need to do more and more fender work as the tire gets wider. So with a 275/35 i would need quite a bit of a fender roll and pull.
now the question here is how much can these fenders be worked before you need to do a serious modifying? And at what point would there be any issues with sidewall collapse
Old May 7, 2017 | 02:07 PM
  #341
Chad05TL's Avatar
why doesn't the tire hangover by 1 full inch if the tire is 265mm which = 10.43". And your rim is only 9.5".
Old May 7, 2017 | 02:32 PM
  #342
Andrew
Because the manufacturer measures from bead to bead, not crown to crown. And also, the mm is never correct, and can vary wildly between tires, and manufacturers.
Old Jun 21, 2017 | 06:52 AM
  #343
ATLS_666's Avatar
3 2 GONE
yokohama sdrives 255/40/17
they run wide so it's more like 265..
Old Jun 21, 2017 | 07:45 AM
  #344
Andrew
Originally Posted by ATLS_666
yokohama sdrives 255/40/17, they run wide so it's more like 265..
Actually, the average TW on a 255/40/17 is 9.4", and your S-Drive is 9.1", so they actually don't run wide. The widest running 255 is the Dunlop Direzza at 10", wider than the average 265 TW, which is 9.7".
Still, 255 is beefy on a TL, great job .
Old Jul 14, 2017 | 05:25 PM
  #345
Boosejars's Avatar
Checking in here, had to get some new tires a couple weeks ago - anyways, went from a 245/40 to a 255/35 on my 18x10 set up. I'm going to need to mess with the front fitment some more (aka pull the fenders more), so the fronts won't rub nearly as much, for now, it's only on the dips that I get any rubs. What a huge difference in feel and control on this new set up. Def not going smaller on tires...they are BFGoodrich G-Force Sport Comp 2 A/S. Driven about 200 miles on them so far, time for an alignment!
Old Jul 14, 2017 | 05:44 PM
  #346
Andrew
255/35, love it!
Old Jul 14, 2017 | 05:55 PM
  #347
Boosejars's Avatar
Thanks brother!
Old May 29, 2020 | 08:35 PM
  #348
Daily Driver's Avatar
This thread needs to come back... 255x40s DWS 06, 15mm all around
Old May 30, 2020 | 04:58 AM
  #349
greekguy000's Avatar
sharp
Looks sharp...just like my old one
Old Jun 19, 2020 | 09:56 AM
  #350
Jason Holland's Avatar
My 04 acura TL on 255/45 Continental sport contact tires with 18×9 42 offset
Old Jun 19, 2020 | 10:00 AM
  #351
Originally Posted by Jason Holland
Liquid metal splice rim
Old Feb 19, 2021 | 12:02 AM
  #352
Charlie Gutierrez's Avatar
3rd gen acura tl with 2019 aspec wheels 245-40-19 50 offset
jyang0311
Sep 15, 2020 07:34 PM
whitedrgons
28
Mar 6, 2009 12:28 PM
Time For Sleeep
33
Jun 26, 2008 08:53 PM
lavo
49
May 3, 2008 05:25 PM
Time For Sleeep
Jan 12, 2006 01:42 PM
