BBS RK 17x8 40 offset
1) Any hope of these fitting with 215/50/17 tires on a comptech drop?
2) Would they look any good? I wanted 18's but these are available pretty cheap (used)
2003 SSM TLS
No, NO, NO. You won't be able to use these, especially with a Comptech drop. You will need at least a 45+ offset, preferably 48+ or 50+. With a 40 offset you will scrape the tops of the back outside fenders and the fronts will probably rub on the fender lips when you go over speed bumps etc... Sorry to give you bad news...
^----agreed
Moderator Alumnus
Originally Posted by -Rz-UA5
Where did u found those wheels? if those are the one that Doraemon from TAC is selling, then I can say it fits.
Originally Posted by Lawaia
17x8 +40 and you say it will fit? I want some of what you're smokin'! :toothless ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Want some of what I m smoking? here you go :tflamer:
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
