backspacing=what offset?
Old Mar 7, 2002 | 06:09 PM
kobe98's Avatar
I'm getting 19x8 wheels and they told me the backspacing would be 6 1/4 inch. I asked them what the offset was and said +45. Can anyone confirm this? Thanks
Old Mar 7, 2002 | 06:37 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
The back spacing is the distance from where the hub mounting surface is to the back of the wheel.. (overall rim width)
You backspace would also be dependant upon how wide your outer rim was. Because you have the rim width(the part where the tire mounts) and then you have the over width(rim width + outer rim)
For a 19x8 wheel with +45 offset to have a backspace of 6 1/4, you probably are looking at a wheel that has a outer rim that is 1/2 inches wide.
So the backspace sounds about right..
So which wheel is it?
Old Mar 7, 2002 | 08:51 PM
kobe98's Avatar
I decided to go with the coddington boyd timeless 2.
Supposedly, you just tell them make and model of car, year, what kind of drop and they will make the wheel w/o rubbing. So I told them 2002 Acura TLS with H&R drop 1.75 in front and 1.5 in the back.
So I dont know if I should stick w/ what they say or tell them to make the offset to atleast +50 like everyone else w/ the same size wheels.
I got to let them know by tomorrow, friday. So any more suggestions. Thanks.
Old Mar 8, 2002 | 12:05 AM
Lawaia's Avatar
Moderator Alumnus
+45 is a bit too little IMHO. Also dependent on whether you're running 225 or 235's. To be safe +48 minimum...optimum +51
neuronbob
23
Jul 16, 2019 10:48 AM
BreezyTL
Jul 26, 2016 12:52 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
