Axis Hiro wheels
Axis Hiro wheels
I have searched, but I need to know if the axis hiro in 19x8.5 et45 will fit over the brembo calipers on the 6 speed. One person said 45mm offset works with the 6 speed while most of you say I need 35mm offset to clear the brakes. I don't want to use wheel spacers. Axis said the 45mm offset will work with my car, so I am confused now.
How bad is your rear rubbing with 35? What tires do you have?
Reason is, my car doesn't really rub in the back, unless I have 2 or more passengers in the back with some load in the trunk. The tires scrape a small portion of the bodykit and no other parts. I have Eibach Prokit, that's rebadged and sold as Comptech too.
Originally Posted by bklynpanman
The 45's definitely positively don't fit over the brembos. 35's do.. Only problem is the 35's on the rear do rub with a comptech drop. I had 35's in the front, and 45's in the rear
JByron
01-08-2016 10:49 PM
