Another Offset Question
Old May 27, 2011 | 07:28 AM
geniusnouman's Avatar
Hey guys i did my research but couldnt find an answer. I am getting a good deal on RonJon Legend 19 X 8" +48 offset. Does anyone know if these wheels will clear the brembos on manual TL.
I see that tirerack.com claims some wheels with +49 offset and 8" width to fit manual TL. but I couldnt find an answer at acurazine as to what's the largest offset that would clear the brembos.
Old May 27, 2011 | 07:49 AM
SharksBreath's Avatar
BANNED
you'll be fine.
Old May 27, 2011 | 08:59 AM
myron's Avatar
I don't know if they will fit, best bet is to PM ronjon or email him or call him. And with that offset your wheels will be so sunken in, 4mm more sunken in than stock. I would get some spacers while i was at it to correct that weak offset
Old May 27, 2011 | 11:28 AM
murph145's Avatar
^ yea regardless if they clear the brembos or not the fitment is pretty weak i would definitely add some 20mm spacers to bring the tires out some
Old May 27, 2011 | 12:10 PM
well i called ronjon wheels and they said it wont clear the brembos. ugh now im wondering if i get the 15 or 20mm spacers, would those solve the fitment problem, besides from giving more of a flush look.
Old May 27, 2011 | 12:15 PM
myron's Avatar
I'd get 20 for the front and 25 for the back. and that will fix it no problem.
Old May 27, 2011 | 12:17 PM
murph145's Avatar
^ yea id probably do what myron suggest
Old May 28, 2011 | 10:02 PM
stvtec's Avatar
'06 WDP TL 6MT
25mm spacer out back is pushing it a bit. I've got 25 in the rear, with stock rear suspension and stock 17's right now, and it just barely clears. On the driver side where my quarter panel was hit and not yet repaired, I get a bit of rub on a good bump. Now, I don't know how those wheels compare in overall size and offset, plus it depends on the tires you plan to run. But 25mm is pretty close on stock setup, FYI.
Old May 30, 2011 | 07:05 AM
raydiddy's Avatar
GTown
^the rims he is getting is at et48 so he might just be ok considering stock rim et is at et45 and your running those 25mm.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
mellsonnj
Sep 24, 2015 04:42 PM
