another alignment question....
Old Apr 19, 2007 | 06:33 AM
JimiThng's Avatar
i just purchased a 05 TL and i noticed that the LEFT side (front and rear) tires are rounded on the OUTSIDE. could this be an alignment problem that can be corrected at Acura under warrenty?? the car has 29,0xx miles on it and shouldnt be having alignment problems at this mileage....
Old Apr 19, 2007 | 06:56 AM
csmeance's Avatar
what tires does it have??
Old Apr 19, 2007 | 07:02 AM
JimiThng's Avatar
hmm i THINK they are stock..Bridegstone?
Old Apr 19, 2007 | 11:54 AM
260 HP's Avatar
How rounded are they? If they are extremely worn out compared to the rest of the tread, you might have an alignment problem.
If it's just rounded, probably the original owner took a lot of right turns at high speed (freeway ramps and the like).
Alignment problem can appear at anytime. If your car only has xxxx miles, doesn't mean it won't be having an alignment issue. Alignment changes as the car ages and puts more miles. Major potholes, accidents, compressed rubber bushings, all these things affect alignment.
Old Apr 19, 2007 | 03:43 PM
wasupdog's Avatar
My Garage not
did u just get this car? if they are still the (crappy) original stock tires they are probably just about due to get replaced. check to see how close the tire treads are to the wear bars. if u get new tires and an alignment i doubt u would have a problem in the future...just keep checking the tire wear every so often afterwards.
Old Apr 19, 2007 | 07:32 PM
JimiThng's Avatar
should i go to the dealership and have them check the alignment? is this a free, under warrenty service? i have 28,9xx miles on the car, 2005 TL
Old Apr 20, 2007 | 12:23 AM
260 HP's Avatar
It's not a warranty item, rather it's part of maintenance. I think the manufacturer will only cover alignment for the first 12k miles or 12 months.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
