All koni shocks riders, what firm position?
i drive mostly city (nyc) trying for first time the koni sport at full soft with h&R sport, it rides really good. would like to know what other acurazine member have then set and your driving condition.
one last question, to adjust the rear shock do i always have to remove the backseat?
In the Summer I run 3/4 turn from full soft, Winter I adjust to 1/2 turn. Perfect for me as our roads up here are pretty chewed up and cold ambient temperatures have an effect on damping/rebound.
If I lived in a warmer all year round climate with glass smooth roads everywhere, I'd be running them at probably 1 turn from full soft....anything firmer is for a track IMO.
To adjust the rears, the seat back has to come off. It'd be great to get an EDC (electronic damping controller) for these and be able to adjust from a switch in the cabin.
Konis should be set based on the spring/swaybar combo you're running. The stiffer the spring the more damping it needs. Shocks control the suspension/spring and body motions. Too stiff ruins handling and comfort. Too soft won't affect steady state handling much but it will take longer to take a set into a corner.
The best advice I can give is to take it around some corners with bumps starting from about 1 turn from soft. Try it in small increments until you feel the body and suspension is well controlled without being too harsh. Basically the softest you can run them while controlling the suspension and body motions.
It's really hard to say without driving it. I have a-spec springs with the H&R 28mm bar up front and I have my Konis just over half way on the firmness.
thanx, i went 3/4 from full soft all around and the different is amazing. i feel like i'm driving a bmw m3 because it feels so stiff and smooth in the road. it is so much fun to drive now. I live in nyc and was concerned about ny street being so harsh that i would not like koni shocks. When the installation was completed i had on full soft and the different was amazing, it felt stiff and like i actually had control over my car. After driving for a couple of day i notice that having a stiff car over a soft was a much better driving experience and started to feel my car at soft setting to soft for me. Now after adjusting it to 3/4 i'm loving this setting but who know if in a few days i still find this setting to soft, This is the best suspentions i have had in any car (h&r sport with koni yellow).
If I could summarize what I learned from your posts on the sway bars subject, the TL-S 27mm solid with Progress 24mm on firm setting is (nearly) balanced on itself, while the H&R 28mm on soft setting is stiffer and requires stiffer rear suspension to balance understeer/oversteer, but it is worth it and gives better overall results in the end, is that right?
What springrates do you have front/rear? I have similar goals with my car like you and I'm going to copy your suspension
The 28/24 required the rear springs to be stiffened. It barely makes a difference in ride quality in the front seats but the rear passengers hate it. On regular summer tires this had hardly any percievable body roll. On the stickier NT05s it has some.
I don't know the spring rates of the A-spec springs but from what others have said, they're stiffer than some of the "sport" springs but softer than many of the "race" springs. I like them because they seem to take away some of the understeer and they're not progressive.
i have mine set to 1.5 turns on the back and 1/3 turn on the front. it really depends on how stiff your springs and sway bars are. i have the type S front sway bar and the prgress on the back set to firm. i have to set the front soft to avoid understeer. you really have to test drive and adjust over and over again. keep records of settings and how it rides till you find what you like. if you get understeer soften the front and stiffin the back. if you get too much over steer you have to sofen the back and stiffen the front. always adjest little by little and test ur car. fine adustments can even go down to different tire pressures. (should be a little higher in the rear) but keep adjusting and testing
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
