Alignment quality
Old Nov 21, 2006 | 06:05 PM
longlost's Avatar
5th Gear
Alignment quality
I've been in an 18 month experiment with Sullivan Tire here in Keene, NH to find out why my tires (Mich AllSPort) are chopped and not improving. He's been aligning and checking and rotating, etc., and came to the conclusion that the rear alignment, while barely in spec, is causing the problem. He said there's no adjustment he can make that can correct the problem.
Next stop: Dealer (Sunnyside, Nashua, NH). They align and get results that show significant improvement, and suggest that the Sullivan Tire equipment is not up to the job, or that Sullivan has an outdated set of specs.
Up to now, everyone has been friendly and (I think) helpful and giving it a good effort. I'm headed back to Sullivan next week to share Sunnyside's results and input.
Anyone had a problem similar to this or have any advice?
Old Nov 21, 2006 | 10:08 PM
csmeance's Avatar
did the tire place use the hunter road force balancing maching?
Old Nov 22, 2006 | 08:49 AM
longlost's Avatar
5th Gear
I don't know. The dealer used a Hunter machine which they bought fairly recently.
Is that the only machine that should be used?
Old Nov 22, 2006 | 08:56 AM
jupitersolo's Avatar
nnInn
I think Acura changed alignment spec awhile back. Sounds like the shop didin't have correct ones. I can't remember where I saw this.
Old Nov 22, 2006 | 11:55 AM
1995hoo's Avatar
Keep Right Except to Pass
There is a TSB regarding the rear suspension on the '04 and some '05s. Perhaps it affects you. See linked PDF:
http://www.in.honda.com/Rjanisis/pubs/SB/B05-050.PDF
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
kb1rl
Sep 30, 2015 10:17 AM
