Alignment issue
Old May 15, 2009 | 12:02 PM
rwatson908's Avatar
Question Alignment issue
My auto is 07 TL/S. It seems there is an alignment issue with my car. It has been tested with present "spec's". The loaded data base indicates only the right rear is slightly out. The store manager tells me, " the current specs loaded may not indicate actual measurement indicators needed to align my TL/S. An Acura update may have been missed!
Any assistance in guiding me to the revised TSB settings would be helpful.
I ride on Yokohama Avid W4S.
Thanks, Ron
Old May 15, 2009 | 02:39 PM
Turbonut's Avatar
Specs for an unloaded vehicle should be fine, unless you carry 1200 lbs with you all the time, or experiencing a suspension problem. Theres is no camber adjustment on the TL, so you'd need to purchase a kit if you wanted to get it into specs alignment.
Does the tire show unusual wear?
Old May 16, 2009 | 05:35 PM
rwatson908's Avatar
Turbonut, Thanks for responding. Yes, according to the Yokohama dealer. He said it appears the tread is wearing on the inside. Ever so slightly, but enough to cause a roaring noise. He said they will probably replace all four tires. I am fine with that!
He feels there has been a change in the TSB regarding the TL/S. Because the alignment showed good(see above) and doesn't explain the inside wear? R
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Sep 14, 2015 10:09 PM
Zonian22
Sep 2, 2015 08:19 AM
