Alignment Help
Old 07-08-2011 | 06:10 PM
nokkieny's Avatar
Alignment Help
Just went to get my car aligned and they checked it and told me it didn't need to be aligned and they adjusted the steering wheel, Anyways, nothing changed.
Brand new tires
Symptoms:
Pulls Right
If I hold the steering wheel in the middle it will pull right gradually
If I center the steering wheel and let go it starts to turn itself and goes right much quicker.
Here is the Report:
Old 07-08-2011 | 09:09 PM
KhizerTL's Avatar
Hey same thing happened with me, you need to buy a camber kit.
Read this https://acurazine.com/forums/showthr...1#post13064061
Old 07-09-2011 | 08:03 AM
nokkieny's Avatar
So did you make the left -.09 and that fixed it?
Old 07-09-2011 | 08:53 AM
Turbonut's Avatar
Just for informational purposes, as they didn't change any adjustments, did the car drift right before the tires/alignment?
Old 07-09-2011 | 09:09 AM
vill0169's Avatar
AZ Track Whore
Does it still pull right if you're in the left lane on a highway? I know it sounds stupid but if you have to account for the slope on the road when dealing with something like this. Cuz really, there's nothing in the alignment specs that suggests a right pull.
Are the new tires the same size as before?
Old 07-09-2011 | 09:42 AM
nokkieny's Avatar
Before the tires it did, but possibly not so swiftly when I let go of the steering wheel. Same as before and after on the "alighnment" as they didnt align anything
Old 07-09-2011 | 09:44 AM
nokkieny's Avatar
I will check if it happens in the left lane and see if it still pulls I kinda remember before the tires it may have actually pulled left at one point so maybe I was in the left lane.
Old 07-09-2011 | 09:49 AM
vill0169's Avatar
AZ Track Whore
Well that shouldn't be a surprise, I would expect them to do that. I would maybe told them to bump out the left toe just a hair and see if helped at all. But really, I bet it's caused by something other than the alignment. Just the roads or some other outside factor.
Old 07-09-2011 | 11:19 AM
nokkieny's Avatar
Same thing happens in the left lane. I think I am going to go back to them and tell them to fix it or give me my money back. If it is a mystery it is probably something I wont waste my money invetigating.
If the steering wheel was set slightly to the left the car would drive perfectly straight if that tells anything
Old 07-09-2011 | 11:23 AM
vill0169's Avatar
AZ Track Whore
I guess I'd try adjusting the left toe out a bit and see what happens. Let us know how it works out.
Old 07-09-2011 | 01:32 PM
Turbonut's Avatar
As noted previously, big difference between the left and right camber.
emailnatec
29
09-28-2018 04:27 PM
Zonian22
11-14-2015 01:20 PM
TxRzrBk
09-17-2015 01:07 PM
Quick Reply: Alignment Help
