Alignment after Aspec install
Old Aug 8, 2005 | 04:34 PM
AnitNO1iLLeR's Avatar
Team AM #123
i install my aspec suspension about a month ago and i dont feel the car pulling to the left or right, its pretty straight, but should i still get an alignment anyway to be safe?, everything seems and feels right
Old Aug 8, 2005 | 10:27 PM
SweetJazz's Avatar
2016 E350 Sport
You should always get an alignment after having your suspension removed. It's good practice and you will have peace of mind not to mention the CYA factor! Cover Your Ass for any warranty work.
Old Aug 9, 2005 | 08:19 AM
Msnowdon's Avatar
Yes, mine was off only a little bit, but you don't want to kill your tires.
Michael
Old Aug 9, 2005 | 08:17 PM
madehtsobi's Avatar
05 WDP TL
any time you modify your suspension, you will need to get an alignment done!
but if you just add wheels.....its ok
Old Aug 10, 2005 | 11:15 PM
TheNip73's Avatar
Overlord - Team Abyss
I had the A-spec installed and they didn't need to realign my car. To be safe though I had 2 different shops do the free alignment check making sure I gave them the A-spec alignment specs. I know others have had similar experiences with not needing the alignment. See if you can get a free check somewhere and don't let on you have a new suspension or they might take you for a ride.
Old Aug 10, 2005 | 11:21 PM
Fast Lavey's Avatar
My alignment was within specs after installing my A-Spec Kit.
Old Aug 11, 2005 | 11:07 AM
MichaelBenz's Avatar
CTS-V Import Slayer
My alignment was off and needed adjusted after installing A-Spec suspension. I would recommend it. There is also different A-spec suspension settings that are listed in the directions. JUST HAVE THEM BE VERY CAREFUL ON YOUR A-SPEC RIMS THAT THEY DONT DAMAGE THEM WHILE THEY MOUNT THE ALIGNMENT TOOLS TO THE RIM. I would highly recommend mentioning it verbally and possibly even writing it on the sheet you sign before they do the work so they know if they mess them up...they will need to replace them.
My rims got flat spots on them durring the alignment process at both the dealer (made them replace all four rims) and then afterwards when I got the A-spec suspension installed at the body shop at a later date.(they denied it) That way, there is no questions!
Old Aug 11, 2005 | 02:52 PM
PoochaKannInc's Avatar
Shift_faster
I recommend an alignment. My alignment was off after the A-Spec install.
Old Aug 11, 2005 | 03:05 PM
TLover's Avatar
Just because you're car doesn't pull doesn't mean you don't need an alignment. The toe, camber and caster could be off and your car will still drive straight.
Old Aug 11, 2005 | 08:11 PM
ChuckDu's Avatar
Originally Posted by TheNip73
... and don't let on you have a new suspension or they might take you for a ride.
Whooaa! Deja Vu. This is the line I got earlier today...
$59.95 for an alignment with a coupon. Then he asked why I thought I needed an alignment. I responded that I installed the ASPEC suspension myself. He said then it's a minimum of 1 hour labor ($75) plus the $59.95 alignment fee.
Is there any good reason for this to be legitimate?
Old Aug 12, 2005 | 12:54 PM
Aegir's Avatar
Powered by Guinness
Sounds like a rip-off. At best it's a misunderstanding on their part. They may be assuming that the suspension change has the alignment way off, requiring more work. That won't be the case here.
Old Aug 13, 2005 | 02:33 AM
SIK TL's Avatar
Shift Gears
When I first bought my car the dealer said that it was natural for the 6mt to pull to one side-free alignment . After installing the aspec sus myself the pull is back, headed to the dealer tomorrow for new alignment so not to destroy the new wheels and tires.
james357
Feb 13, 2016 02:37 PM
Zonian22
Nov 14, 2015 01:20 PM
njresendez
Sep 24, 2015 11:41 PM
Sep 14, 2015 10:09 PM
Zonian22
Sep 2, 2015 08:19 AM
