3G Acura TL rear tire wear help!!!
Ok so first off im new to the forum so please bare with me. So I recently bought a 2006 acura tl auto with 150000 miles on it, it drives like a dream but just recently notice road noise and checking the rear tires im getting strange wear on the inside that is bumpy, and like a saw blade (can slide hand over easily and feel bumps, and go the opposite way and I hit the raised parts of the tread. So today I when to have my alignment checked and the front tires were in spec, but the rears was
left rear right rear
-1.5 camber -1.4 camber
-0.19 toe -0.51 toe
they told me I need my struts replaced but I just wanna be sure and only fix what is needed. Please Help !
-0.19 toe -0.51 toe
No, I just wanted to get it checked and plus they did it for free. I just don't want to replace my struts if I don't have to. if just getting the alignment will solve my issue ill do that. they tires are pretty much toast, im just gonna wait till I get new tires and struts if I have too.
Sounds like you know what youre doing. Wait tile you get your new tires then have the alignment done when you get them. If its still bothering you fix it more. BUT if its not right your new tires could be in jeopardy. I dont know that much about these cars suspensions but I wouldnt think old struts would knock it out of alignment that fast. I would get a free alignment check within the next 6 months with the tires and utilize that to see if the alignment comes out again.
I couldn't tell what brand of tires you have but my TL loved to eat Michelin tires for some reason. After the OEM set wore out at 22k miles, I had a 4 wheel alignment (rear toe was -.04 left, +.16 right) thinking my problem would go away for my second set of Michelin tires. Sure enough those tires were shot at 24k miles. I finally changed to Yokohama and have 21k miles on those with no signs of outside wear.
Unusual wear patterns is usually a sign of a bad strut or suspension component.
they look cupped to me. That is from a weak shock not being able to keep the tire in contact with the road and wearing as such. new struts
polobunny (04-13-2015)
150K miles and 9 years? Likely it's still the original, i doubt non-car enthusiasts bother with replacing shocks and struts especially if they go and sell it a few years later.
Most likely, so should I just replace the struts and then get it aligned? And what are the possibility the the rear control arm link bushing are warn out and ca useing my suspention to sag?
No, get the toe fixed first.
I tryied to check for oil leaking from the strut but for the life of me I couldn't get the boot to slide up to check, as for the bounce I did that and it stopped after one bounce.
2007 TL
Same issue
I have the same issue, but is the front tires, 118,000 miles original struts. At first I thought it was the tires, then I got a second different brand set of tires, still the same problem, I aligned the car every 3-6 months and still the toe was coming out of alignment. So it's probably the struts/shock or bushings, front compliance bushings.
I installed new compliance bushings today and will be getting new tires and an alignment soon! Hopefully that'll rectify the issue!
I 100% agree with the firestone alignment! It's well worth it, but I believe you can get an alignment every 5000 miles or so.
nanos
11-12-2015 08:41 PM
merc009
10-03-2015 12:59 AM
asahrts
09-04-2015 05:55 PM
