30mm offset -- Will it fit?
I'm about to buy some replacement tires & wheels for my 2007 Acura TL Type S. I'm getting them 2nd hand, so I cannot get one in a different size at this price. The rear wheels are 19X8.5in with a 33mm offset and the fronts are 19X8in with a 30mm offset. The offsets are on the lower limit of what I've seen posted in threads. Will these wheels fit or should I look elsewhere? Also given that it's a FWD car, should I swap the fronts and rears as listed above, putting the wider in the front?
no don't put wider wheels in the front. Keep them in the back and you will be fine. And as for the offset, you will be fine, they won't stick out or anything like that. But, question is will they clear the front brakes. Telling us what wheels you are getting will give you better answers.
quanaman
01-09-2023 07:33 PM
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
xsilverhawkx
09-28-2015 06:51 PM
