25mm Spacers with Stockies?
Hey does anybody have a pic of 25mm spacers with stockies?
I've searched around forums and I haven't had any luck finding pics.
I'm thinking about changing my tires soon as well, will having 245/40/17 tires and 25mm spacers make a difference? I'm trying to go for that flush look.
BANNED
i've got stock type-s wheels 235/45/17 w/ 20mm in rear and 15mm in front and it's perfect. flush as can be in the rear and front.
with your future 245/40/17's...i am not entirely sure. hopefully someone else can chime in and let you know.
BxTrini_TL (11-02-2013)
I currently have 15mm all around with 245/40/18. I have a set of 20mm I haven't got around to throwing onto the back yet. I will do that soon and let you guys know if it rubs.
I remember a member here put FiC spacers on his car... It's a black car. Forgot his name. It looked pretty good...
http://www.more-japan.com/fic-wheel-spacers/
I have 25 rear and 20 front on stock wheels and suspension, looks much better and no rubbing. Whatever size spacer you go with get 5mm less in the front to even everything out. I think 245s will be OK, but research the actual tire because the actual dimensions of 245 tires between brands can be different.
BANNED
a monkey could install these. bolts right up
Here is a member with 25mm's on Type S wheels and Tein basics. He says he doesnt rub unless he has car full of people.
https://acurazine.com/forums/3g-tl-photograph-gallery-96/25mm-long-cbp-type-s-785061/
![](http://farm5.static.flickr.com/4081/4826210300_28d65d6bc2_b.jpg)
BANNED
Are you dropped in these pics? That's the ideal flush look I want with my stocks. Very nice. 15 f and 20 r right? Ichiba Version II? Are these stock tires or wider?
Any problems with them. Turning, going over pot holes, rubbing, etc..?
BANNED
only dropped on 1" eibach springs/stock shocks. yup, 15mm up front and 20mm in back. ichiba V2 spacers on stock tires.
no problems at all turning or anything. it was a good setup for me at the time.
245/40/18 on with 18x8 ET45mm (like stock offset) with 15mm front and 20mm rear on A-Spec suspension. The back rubs slightly with a person in back on huge dips that compress the rear a lot. I haven't seen any indications of tire or fender damage. It's only on the driver side too.
I think 25mm rear spacer on stock wheels with 235/45/17 will have similar issues. If you were running 245/45/17 and 25mm spacers, I have no doubt you will rub.
Does anyone use H & R trak+ wheel spacers? ![](http://www.trakplus.com/images/header-front.jpg)
They look and appear to be the best out there.
Found similar hub centric spacers only in 20mm have no 15mm for front wheels such as these on ebay
http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWAX:IT.
Or should i go with ICHIBA V2 found some folks had problems with the studs with these?![](http://ep.yimg.com/ip/I/yhst-74684326539276_2053_479590)
Any suggestions?
![](http://i847.photobucket.com/albums/ab35/supers13240sx/BToptionselects/Spacers_5lug_51.jpg)
Any suggestions?
I've been using H&R products on my VW's for over 10 years and have never had any complaints, haven't tried ICHIBA so can't help there.. but have 20mm spacers on the rears/15mm fronts from the Ebay seller in the link you listed. Good quality product imo
Maybe better off getting the eBay generic spacers but will need to look for 15 mm somewhere else.
Just worried the pressed in stud bolts are weak not oem specs?
After the install i might order local parts distributor in Vaughn for H&R trak+ for 15 mm for front wheels. For $150 plus tax just to make front and rear flush.
Or i might look somewhere online for some ichiba V2?
Looks like I'm going to go with 20mm spacers in the back and 15mm spacers in the front. I would try 25mm spacers all around but I don't want to risk it since my tires are 245s. The pictures that SharksBreath put up really convinced me. Thanks bro! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
And for those that are still looking for spacers, check out this thread: https://acurazine.com/forums/showthr...=spacers+stock
I'll be picking up the Akata spacers soon.
For $139.90 shipped for 20mm front and 15mm rear, it's a pretty sweet deal!
i got 15mm spacers for the front with no studs attached smh...i cant return them..anyone know what length extended studs i need please help ive been looking for a week now. i have a 2008 acura tl on 17 stocks......or what company has extended studs\
I have the same setup as yours but Im thinking on going with 25mm. Do you think this one will rub?
'06 WDP TL 6MT
(This is all regarding the rear) I had stock 17's on with 235 and 25mm spacers and I got some rubbing on the drivers side, but the fender had been pushed in due to an accident. The damage was repaired, and I put on the 18's with 235 tires right away, and now rubs both sides. However, this is at STOCK HEIGHT in the rear.
BANNED
The following 2 users liked this post by SharksBreath:
BxTrini_TL (11-02-2013),
stvtec (06-29-2011)
