which 225/55/16 for stock rims in NE
Hi guys,
I got a flat yesterday. Looks like I have to change the tire.
I was thinking of Sumitomo HTR+ but they don't come in 225/55/16. I was wondering if anybody could help me choose the decent All Season 225/55/16 tires for my stock 03' TL-P rims?
I live in NJ so I need something with good handling in snow also.
l33t
I researched this for HOURS actually...
The Sumi's are close, but are still a little off, you will have a change in your speedo.
By the end i was debating between Kumho 712's or Bridgestone RE950's... I went with the 950's in the end. very happy. their also the closest tires to the stock MXV4's.
Yes, it will not be exactly the same as stock, but it will actually slow down your speedo with that size, i.e. 225/55/16.
Darkshear
Aren't Bridgestone RE950 rated H. And I guess thats allright for you since you don't have to worry abt living in the snow.
SilverUA5
I know about the speedo, any solutions? can it be fixed?
SilverUA5
rw
Originally posted by sparky57
The stock Michelin MXV4 Plus diameter is 25.6" with 813 revs @ 45 mph whereas the Bridgestones are 25.7" in diameter with 811 revs @ 45 mph. Are you worrying about a miniscule 0.25% difference? My speedometer still indicates 4% fast with the 225/55 RE-950s using timed trials between milemarkers.
rw
rw
How good are RE950s?? How's the ride? Are they quiter than stock michelins?
Originally posted by ash3ktl
No I'm not worried about the RE950s. I wanted Sumi HTR+, but can't get for 225/55/16. The only size tirerack has is 225/50/16, which I'm sure will affect the speedometer.
RE-950s are considered "performance" tires rather than "touring". Consequently, they are somewhat noisier and harsher riding than stock. They are however, significantly better at handling, both wet and dry, which is why I purchased them.
rw
Oh one thing I forgot to mention is is it allright if I change the front 2 tires with RE950s and kept back 2 stock?
Are they the same size? If not, I don't recommended. As for the 225/55 size, you can give the Yoko AVS dB S2 a try.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
4drviper
09-23-2015 09:00 PM
