20mm rear spacer on A-Spec wheels, is it too much? Pics inside.
Old 05-04-2010, 04:27 PM
  #41
vash337's Avatar
i agree, i was just curious. i would have put the 2 20's on one side just to see it
Old 05-04-2010, 04:29 PM
  #42
08A-SPEC's Avatar
Here is how the car looks from the side with 20mm in back and no spacer in front. Just looks a little weird now.
Old 05-04-2010, 04:30 PM
  #43
08A-SPEC's Avatar
Yes, I didnt want to bother because I know the front will be too far out. 20mm in back and 15mm in front will be flush front and rear.
Old 05-04-2010, 04:32 PM
  #44
vash337's Avatar
will look good. do the stock rims have room for the stock studs to stick thru the spacers? or are you replacing your studs w/ extended ones?
Old 05-04-2010, 04:34 PM
  #45
08A-SPEC's Avatar
These adapters have their own studs. Yes the stock wheels do have extra spaces for the stock studs to fit into.
Old 05-04-2010, 09:48 PM
  #46
I Fly STi's Avatar
flush for sure
those aspec wheels the same width as the reg 3g tl wheels??
where you order the spacers from??
Old 05-04-2010, 10:42 PM
  #47
08A-SPEC's Avatar
Originally Posted by I Fly STi
flush for sure
Yes these are 18x8" A-Specs, same width as factory 17's.
http://www.optionimports.com/itemdes...511464B&eq=&Tp=
Old 05-07-2010, 01:37 PM
  #48
08A-SPEC's Avatar
15mm spacers are installed on the front now, some teaser pics for now until I can get the car cleaned from todays rain. HUGE difference now with all 4 spacers in.
Old 05-07-2010, 02:10 PM
  #49
vash337's Avatar
lovin it
Old 05-07-2010, 03:31 PM
  #50
socal WDP
diskinnect's Avatar
i think they look good
Old 05-07-2010, 10:05 PM
  #51
Area on my XM
Red Voodoo's Avatar
Hmmmm... I'm on the fence on this one. I'll keep an eye out for more pics.
Old 05-08-2010, 09:32 AM
  #52
08A-SPEC's Avatar
Red Voodoo share your thoughts, what doesnt seem right?
Old 05-08-2010, 12:33 PM
  #53
Area on my XM
Red Voodoo's Avatar
I don't know... lol I think it's one of those things that I need to see in person. Perhaps the pictures aren't doing it justice? It just doesn't, well, for the lack of a better term, move me. Maybe it's the angle of the photoshots?
Old 05-08-2010, 12:41 PM
  #54
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
better pics??
Old 05-10-2010, 10:21 AM
  #55
WOT in the new ATLP V2s!
Izzy-Type-S's Avatar
Nice! I take it your keeping the 20mms? I'll place my orders tomorrow. Nice looking exhaust too!
Old 05-10-2010, 12:13 PM
  #56
08A-SPEC's Avatar
Originally Posted by InFaMouSLink
better pics??
Old 05-10-2010, 12:15 PM
  #57
08A-SPEC's Avatar
Yes, Im keeping the 20mm. After putting the 15mm in front, they are the perfect width now. The exhaust is awesome!
Old 05-10-2010, 12:20 PM
  #58
Your car is quickly looking amazing! Thanks for the pointers on the spacers glad they worked.
Old 05-10-2010, 12:26 PM
  #59
Veni, vidi, vici
Bayam0n's Avatar
any rubbing?
Old 05-10-2010, 12:31 PM
  #60
I used to own a
RedAggie03's Avatar
running 235's or 245's? Yes any rubbing?
Old 05-10-2010, 12:38 PM
  #61
08A-SPEC's Avatar
Thanks Izzy, I had spacers on my previous cars, so I was familiar with all the measurements, just because Ichiba didnt have them listed specifically for the TL, I knew they would fit by the hub and bolt pattern measurements alone. These in person make a big difference in the size of the wheel with it being pushed out.
Old 05-10-2010, 12:40 PM
  #62
08A-SPEC's Avatar
Originally Posted by Bayam0n
any rubbing?
None
No rubbing at all running 235/40's and no fender rolling here. If you run 245's you can run 15mm spacers in rear and 10mm in front to be safe.
Old 05-10-2010, 01:19 PM
  #63
I was about to change my set of tires and was probably gonna go 245s, you're saying those will rub? oh well, I'll cross that bridge when I get there, I like the look of the 20mm rears
Old 05-10-2010, 01:30 PM
  #64
I used to own a
RedAggie03's Avatar
That's kinda what I was thinking that the 245's would rub with the 20mm rears...maybe I'll just run 15mm all around with 245's?
Where did you buy them?
Old 05-10-2010, 01:42 PM
  #65
08A-SPEC's Avatar
Not sure if it will definitely rub but with 245 wide tires you will be 5mm closer to the fender than I am on my 235.
245mm-235mm=10mm divide that by 2 with 5mm wider on each side of the wheel.
Old 05-10-2010, 01:45 PM
  #66
08A-SPEC's Avatar
Pproblem with running the same size all around is that when stock, the front tires already stick out wider than the rear. The smaller spacer in front evens the stance out.
cheapest place I found to buy is here: http://www.velocitymania.com/Product...de=WS-5511464B
Old 05-10-2010, 01:48 PM
  #67
I used to own a
RedAggie03's Avatar
Correct specs?
Bolt Pattern : 5X114.3
Center Bore : 64.1
Thread Type : 12x1.5
I thought our threads were 12x1.25?
Old 05-10-2010, 01:50 PM
  #68
I used to own a
RedAggie03's Avatar
Search answered my question...12x1.5"
Old 05-10-2010, 01:51 PM
  #69
08A-SPEC's Avatar
^^ Yep, those are correct!
Old 05-10-2010, 05:53 PM
  #70
Chapter Leader (Central Florida)
LostSol's Avatar
Izzy - Im going 255/40R17 soon... let me know how they do with the 245's! Id love to do spacers until I go crazy with some rims.
Old 05-10-2010, 07:10 PM
  #71
^ yeah same here, dont know which direction I'm going with wheels , yet so I will do spacers for now on my stockies....which I love...wish they were at least 18s! You're doing 255s all around? Let me know when you get them.
Old 05-10-2010, 07:13 PM
  #72
LostSol's Avatar
yeah found 255-40ZR17s for around $100 each, just trying to decide between
Falken Ziex ZE-912 or
Nexen N7000
And sorry I'm thread-jacking!!! Love the A-Spec's with the spacers OP!
Old 05-11-2010, 09:16 AM
  #73
08A-SPEC's Avatar
Thanks! No worries, discuss away, it all has to do with spacers and larger tires.
Old 05-11-2010, 09:18 PM
  #74
Nexen N7000
Where? Are they used?
Old 05-12-2010, 03:39 PM
  #75
08A-SPEC's Avatar
more spaced out.
Old 05-12-2010, 04:24 PM
  #76
B A N N E D
MyTL09's Avatar
Clean ride! Keep up the great work!
Old 05-12-2010, 05:17 PM
  #77
LostSol's Avatar
http://www.tires-easy.com/
Hell they have Nankang NS-1 for 69 each and Hankook VENTUS H405 HR II for 83 each but I dont know about the quality of either of those!
OP- Shit is looking hot! Spacers make a huge difference, and the roof spoiler is nice too!
Old 05-12-2010, 06:05 PM
  #78
JORTS's Avatar
car looks great bro...WDP FTW
can you provide pictures of your car before you put the spacers on? is it your drop that caused the need for the spacers? i just ordered the 2004 ASPEC 18x8.5 rims...i will have stock suspension...i dont think i will need any spacers...correct me if i am wrong? and with stock suspension, should i get 245-40-18's? or 235's?
Old 05-12-2010, 06:09 PM
  #79
JETSPD1477's Avatar
sparkle silvers?
Old 05-12-2010, 07:34 PM
  #80
08A-SPEC's Avatar
Thanks MyTL09, Ill let you know about a shoot with you local guys!
Thanks LostSol_FoundTL!
Thanks Jorts, here are the closest before and afters I can find with similar angles. The TL wheels even at stock height are in too far. Your 8.5" A-SPEC's will have same offset as my 8" A-SPEC's so you will only get 1/4" closer to the fender, the other 1/4" will be wider on the inside of the wheel being closer to the shock, so you would need spacers too to get flush. I would do 15mm rear and 10mm front on those. 245 or 235? dont know.
BEFORE
AFTER
Originally Posted by JETSPD1477
sparkle silvers?
Yes, Sparkle Silver.
Quick Reply: 20mm rear spacer on A-Spec wheels, is it too much? Pics inside.
