20'' wheel help??
Old Jan 23, 2008 | 07:03 PM
jkgsxr's Avatar
4th Gear
20'' wheel help??
ok I have read lots of posts on here and have also talked to someone at a wheel shop, and am still not sure what is right? I want to run 20x8.5 wheels with 245/30/20 tires the question i have is the offset the wheel shop said i should go with a 35 mm offset because a 45mm offset would push the wheel too far out toward the fender, from what i have read that is the opposite?? would the wheel on a 35 or 45 offset be out closer to the fender?? and which would work better? my car is a 08 type s
Old Jan 23, 2008 | 07:36 PM
Ac_Attack's Avatar
Not your moms TL.
i just bought a set of 20 X 8.5s with a + 38 mm offset. they clear great..
mine is an 07 TL-S
Old Jan 23, 2008 | 08:20 PM
MICHAELBPR's Avatar
BORICUA
Ok, the lower the number the more the wheel will be pushed out toward the fender, the higher the number the more the wheel will tuck in to the fender. I wouldn't go back to that shop, they dont know shit. You can play with the offset numbers here http://www.1010tires.com/WheelOffsetCalculator.asp
On wich wheel would work better is going to depend on the style of wheel. What brand are you getting? For us with BBK we need to look for offset and wheel style. I had SEVAS S22 20x8.5 with a 40 offset and it did not cleared the BBK. I just got WORK wheels 19x8.5 with the same offset and it clears. My advice, test fit them before you get'em. Hope this helps
Old Jan 23, 2008 | 08:30 PM
Ac_Attack's Avatar
Not your moms TL.
yeah i went out on a limb and bought mine while i was in cali....going on DUB mag's word that would work.... TIS 12's 20X8.5 w/ a 38 mm offset clear, since diff wheels work diff.
Old Jan 23, 2008 | 08:51 PM
jkgsxr's Avatar
4th Gear
part of my problem is I have no where around me to test fit any wheels I like without buying them and then finding out. None of the wheel shops arround me have many wheels in stock and most have just turned me away telling me they dont have anything that will fit my car... I really like a wheel that is simular to the sevas s-22, its menzari m sport 20x8.5 35mm or 45mm offset just dont know if will clear the brembos
Old Jan 24, 2008 | 12:18 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
35mm will probably clear... if they don't... then get a 3 to 5mm spacer... good luck...
Old Jan 24, 2008 | 12:34 PM
Ac_Attack's Avatar
Not your moms TL.
I feel ya with that prob...everytime i go to look at books for 3 peice...I get "you're not going to want those...too much $$$" [sorry man, i'm a car guy...I dont have a problem spending extra money for a luxury set of wheels]...then I get into being staggered...and I get..." you DO know your car is FWD, Right?" no jackass i didnt...thanks for the info...now I can take my business elsewhere...
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
JByron
Jan 8, 2016 09:49 PM
GhostTL09
Sep 19, 2015 01:57 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
