20 inch rims question
I am thinking about getting the 20" Konig Unknowns, and was wondering if they would fit on my car. Just a few questions. My car still has stock suspension
Would they rub?
Would it affect performance/ride?
If they would rub or something I would just get 19", but I deffinatly want to go 20s if they'll fit.
Would they rub?
I think this is supposed to go in the Tires, Wheels, & Suspension Sub Forum.....you would get more answers there!
But what is the offset on the wheels, and what size of tires are you planning on goin with?
VS#03
Retired!!! ON TOP!!!
The konig unknown rim will fit... but aren't they too narrow and the offset too high... they only make that rim in a 20" dia. x 8" width... and with a 45mm offset...
In my opinion... the rim is going to sit INSIDE the wheel well too much... The car is going to look funny... just my opinion... to each his own... I like those rims... I used to have them on a project civic I used to own...
Originally Posted by K-Shawn
This is the tire & wheel forum......I have 20's on my TL and I don't have a problem. The set up most commonly used for stagged setup is 35mm offset with 245/30/20 in the front & 255/30/20 in the rear tire size. Rim size 20x8.5 front & either 20x9.5 or 20x10 in the rear. If you have a A-spec kit you have to alter the rear kit right where you would install the rear mud guards. Do a search on 20's and that should also help you out.
https://acurazine.com/forums/forumdi...0&daysprune=60
Check in the middle of the page and it will show this thread with an arrow, or am I the only one that sees that thread!
BTW here is pics of someone with those rims
Middle of page...
https://acurazine.com/forums/showthr...ighlight=konig
Or directly to post that has the pic
https://acurazine.com/forums/showpos...8&postcount=23
Middle of page...
09-15-2015 06:44 PM
nuldabz
09-03-2015 05:49 PM
