+20 or +25?
what would be required to run a 18x8.75 with +20 i want these new xxr 527's but am very concerned i will order the wrong ones. they one come in +35 or +20 and i think +35 wont look as concave and be to sunk in
Chapter Leader (Central Florida)
actually, 18x9.5 +20 is near perfect flushness for the rear, and 18x8.5 +25 is pretty flush for the front, assuming your low, you would need to stretch the tires and roll the fenders
im on middle perch on my supercup kit. would i just need to roll my fenders then or do i need to add more negative camber? i want to go et20 all the way around so i can rotate tires
18x9.5 +20 is WAY agressive for the front, your talking about 10mm of poke! You would have to do an insane stretch, and run tons of camber, and do a fender roll and pull to even try it
18x8.5 +25 might be better for you if you want all 4 rims the same. You wont be flush, but you wont rip your fender off either
boost 3G
i have 18x9.5 +20 with a fender roll and minor stretch..lowered about 2 inches all around...its looks great and wouldnt get anything more or less aggressive
and running 225/35 tires
nuldabz
09-03-2015 05:49 PM
i_g0tz_s0l3
03-23-2011 01:24 PM
