19x8.5 +40mm offset with 25mm spacers
Old Apr 27, 2012 | 07:39 PM
jnoone's Avatar
If I have the offset above, will the wheels stick out past the fenders?
I put a rotora bbk on and now the wheels do not clear without spacers. Just wondering what they are going to look like with the 25mm spacers.
Old Apr 27, 2012 | 10:16 PM
The Machine's Avatar
Registered Member
Yes, I believe with a +15 offset after adding spacer, that your rims will poke outside the fender. I'm going to be running a similar setup but with 15mm spacers, bringing my offset to +23 so I don't quite think mine will poke out, but they will be damn close.
Old Apr 27, 2012 | 10:29 PM
jnoone's Avatar
Man I hope they don't poke out too much. I have an aspec suspension so I am not that low. Hopefully it will not be noticeable.
Old Apr 27, 2012 | 10:49 PM
Registered Member
I don't think it will be extreme, but +15 is a pretty low offset. It may poke some, but if not you'll be really flush with the fender. Whatever size tires you are running is also going to make or break this look as well.
Old Apr 28, 2012 | 01:08 AM
anx1300c's Avatar
Won't look good with A-Spec suspension. They will come out 36.35 mm more than a stock 8" wheel. Grab a ruler and measure for an idea where they'll end up. I mean, it's doable with stretching, rolling, and some negative camber, but you'll need to be lower for it to look good.
Old Apr 28, 2012 | 07:56 AM
Registered Member
^^^ I agree with the aspec suspension and that low of an offset rim, it will look awkward.
neuronbob
23
Jul 16, 2019 10:48 AM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
