19's and what tire pressure??
what pressure do most of you run these at?
Also lowered with tein tech s springs and koni shocks
Summer...
winter...
Summer...
winter...
blownby, it depends on what you want your tires to do.
you gave us no information on what kind of tire you have, what kind of driving you do, what size tires you have, etc.....
everything that is needed to determine tire pressure, you left out.
or you could just go by the stock tire pressure on the door sill, to make it easy on yourself.
like i mentioned; if you wanted to play with your tire settings; you'll need a reason why.
do you need to play with tire settings because of tire fitment and how low you are?
do you need to play with tire settings because you want to maximize MPGs?
Do you need to play with tire settings because you want to maximize traction?
what do you want out of your tires?
I run mine 1 psi for every inch over stock ,,, it was suggested 2 psi but I found once the tires got to temp they were inflated too close to the max.
blownby (10-23-2014)
I have different tires than you.
I want different things than you.
my tire pressure will be very different based on what I want the car to do.
the stock tire pressure is 32/33
if you're so ever inclined; raise it a bit to see how your car reacts day to day.
it doesnt hurt to raise; and you'll be experimenting and finding what works BEST for you.
I have experimented, a bit. ran it at 38 psi this summer.
runs good, wears fine, good mpg, just a bit rougher ride.
??More air pressure (38psi) less likely to hit rim if pot hole encounter than say (32psi) or just more likely to blow tire??
Some people might be surprised what their tire pressure goes too when the tire heats up. Setting the tire pressure at 70 F ambient in the shade ( which is suggested base line per Tire Rack ) then get a day where it hits 90F and run on the highway for a few miles then check them .. could be a surprise.
Anyway .. just food for thought.
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
HeloDown
09-08-2015 06:51 PM
