19's 8.5 42mm off set for 2004 TL???
Welcome the board. There is a post at the top of the page that lists the 04 fitments, but here they are:
17inch ------> 17x8 35-40et w/ 235/45-17
18inch-------> 18x8 35-40et w/ 245/40-18
19inch-------> 19x8.5 40et w/ 245/35-19
offset determines how far out or tucked in the mount is to the hub. higher tthe number, more tucked in, lower the number, the more the wheels stick out from the bidy, like the lowriders. you can def fit 42 offset, it's actually better than a 40 offset, closer to the OEM 45 offset. the A-Spec wheels are 18" x 8.5" with a 45mm offset, so...
braveheart
09-07-2015 08:12 AM
