19's or 20's???? That is the question...
2012 TL Tech
Ok guys I've been reading and reading and have a couple of questions. I know the tire I want to go with (235/35/19or20) so my question lies in the issue of clearance. Will a 20" rim with235/35/20 clear without rubbing? You are asking what is the offset of the rim?? THATS my subquestion. On 19' with the tire size stated above, whats the max offset i can get so not to rub? 20? I'm having a difficult time finding the style wheel that I want for this particular TL .So i'm wondering if I should say F it and start in on 20's.....SOMEBODY PLEASE...help...
Duke
Duke
I ran 245/35/20 with a 40mm offset on my 04 TL and I wasn't even close to rubbing. Check the FS link in my signature to see pictures of my previous wheel/tire set up.
From experience, stick with a 30 series tire for the 20's and a 35 for the 19's.
Don't rush into any purchases. Keep looking around until you find something that you absolutely love.
^No problem man. Good luck with finding yourself a set
I was running 245's on a 8.5" wide wheel, so you should run 245's on your 9" wide wheel. If you are on stock suspension you shouldn't rub.
Yep!
^Will do!
2012 TL Tech
Ok, so what product do I go with to drop the car. I dont wanna do moe than an inch or 2. The streets here in Memphis are NOT exactly what one would call smooth. SOOO INPUT GUYS!! If I go 19's with 235/35/19 tires, how low can I drop it and with what GOOD product would I go with in order to do the drop?
Under construction
Josh at Excelerate or Marcus at Heeltoe
http://www.heeltoeauto.com/home.php?...c0c493b12f2f41
http://store.excelerateperformance.com/
or try ebay for the megan coilovers.
2012 TL Tech
FOR THE RECORD!!! I SHOULD'VE GONE WITH THE 19's!!! I dont like the lift that my car took with the 20's. I DONT like every time I hit a generous bump, my shit gets BENT!!! I'm DONE!!!! Damn!! But the 20's do look fly!!!
Exactly why I sold my 20s. I hated how my car looked lifted like a truck
18s and 19s + a drop FTW
2012 TL Tech
Done with rims............................rocket:
2012 TL Tech
Yeah ron it does... I Just wish I would've gone with my gut and did the 19's..... I like the rims on the 4G but they changed the f'n bolt pattern so we couldnt change the parts around... bastards....
