19inch wheels+25mm wheel spacers, will it fit?
hey guys i got a stock 04 TL, im thinking of getting these rims in 19inch.
http://www.1010tires.com/wheel.asp?w...2FMachined+Lip
also i love the look of a wider stance, so i think im going to add 25mm (1inch) wheel spacers on it as well.
so my question is will i have any problems (rubbing against fender) or anything with the 19inch rims+25mm wheel spacers? any input appreciated, thanks
BANNED
what width wheel are you getting from that list? what offset? 25mm spacers will be too aggressive for either one you choose IMO.
BANNED
8.5 front with what offset? they offer 20 and 38. if you put a 25mm spacer you'll be at -5 or +12. Both of those numbers are aggressive.
9.5 rear with what offset? they offer 30 and 38. if you put a 25mm spacer you'll be at +5 or +12.
if it were me, I'd get the following specs...
19x8.5 +20 FRONT and run 225/35/19 tires.
19x9.5 +30 (add a 5mm spacer...making it +25 afterwards) REAR and run 225/35/19 tires.
Those specs will give you a flush set up. be prepared to roll fenders. I hope you have coilovers as well so that you can lower your car and pull off the stance. you will need to run some negative camber as well.
wuhantang (12-25-2011)
+38mm offset front and rear. I was going to do staggered also and called a place that knows what they are talking about.
I was going to get AXIS SHINE. 19"x 8.5" in front with +35mm offset to clear Brembo brakes with 245/35/19" tires. And +40mm off set in back with 19"x 9.5" wheels with 275/30/19" tires. Front are 9.8 inches wide. baack are 10.8 inches wide. And the same height.
GOD BLESS
GOD BLESS
I called WHEELNEXT.COM and asked about the AXIS SHINE wheels. They said AXIS no longer makes them----WRONG.
I called WHEELSTUDIO.COM and they had ALL THE CORRECT ANSWERS and knew what they were talking about.
DONT believe what people say. DO RESEARCH. Some are right, and some aren't.
GOD BLESS
HAPPY BIRTHDAY JESUS
GOD BLESS
mtl_ilx
09-03-2015 09:48 AM
