19" Ronjon Wheels 245/35/19
I have found a set of Ronjon Legends for sale on ebay...does anyone know if the tire size 245/35/19 will truly not rub on a TL with an A-spec suspension?
if they are for a tl they will not rub with an aspec suspension... for sure..
you might want to get exact specs as the wheels vary from from car to car..
i did not find them on ebay so i can't tell you if they are the correct ones for sure..
I have the RonJon Inspires with 245/35/19 with TEIN suspension dropped low, about 12 1/2 inches from ground to fender...it rubs very, very rarely. I had it dropped to 12 inches from G to F and it rubbed all the time. I can't speack to the ASPEC suspension, don't know how much lower that is from stock.
Good luck
FizzyStatus!
Good luck
Good luck
Thanks is that what you used on your TL? If not what suspension do you have?
JByron
01-08-2016 09:49 PM
