17x8 vs. 18x8
Old 03-28-2005 | 07:30 PM
Bob05tl's Avatar
17x8 vs. 18x8
Can someone explain to me the difference in the sizing of stock 17x8 vs. A-spec 18x8? I know the radius is bigger, but is the width the same or is it a ratio like a tire size?
Thanks.
Old 03-28-2005 | 08:28 PM
PoochaKannInc's Avatar
Shift_faster
The width of the wheel remains the same at 8 inches.
Old 03-28-2005 | 09:27 PM
Bob05tl's Avatar
So, if I buy the a-spec rims, they will not stick out any further than the stock rims, however they will fill the wheel wells better? Better yet, will it provide a wider footprint? I am guessing not.
Old 03-28-2005 | 09:33 PM
EMF213's Avatar
Width is the same but you get less sidewall on the tires; this supposedly leads to a stiffer sidewall (depending on the tires I guess...) and better handling.
Old 03-29-2005 | 11:42 AM
Bob05tl's Avatar
Thanks. So if I purchase 245/45/17 for my stock rims, I will get a wider tire/look than the a-spec rims? Also, in theory, I will have more contact with the road, thus better handling?
Old 04-23-2005 | 07:24 PM
PimpaLicious's Avatar
18's r probably better for cosmetics but you may get increased performance and braking from 17's
Old 04-25-2005 | 04:38 PM
EMF213's Avatar
Not sure about that. Yes, you'll get a wider tire but you'll also get MORE sidewall.
I'm not an expert, but I'd think less sidewall and hence a stiffer sidewall would be give better handling. At least better than a wider "mushier" tire...
Pimp, Why LESS performance from the 18s???
BreezyTL
07-26-2016 01:52 PM
mrkingstonvi
02-22-2016 02:53 PM
usdmJON
ILX Tires, Wheels & Suspension
11-13-2015 08:06 PM
Inspire08
10-30-2015 05:00 PM
acuradriver925
09-12-2015 09:25 AM
Quick Reply: 17x8 vs. 18x8
