17x8.5 +30 on stock height
Old 07-11-2016, 01:49 PM
Grocery_Getter's Avatar
Hello all. I've been searching on the interwebs for a few months now trying to find the right rims for my TL with the brembos. I found some SSR 17x8.5 rims that have a +30 offset, and I really like how they look. My question is: how much poke would there be on the front with this setup on stock suspension? I know the rear will be pretty much flush. I'm planning on running stock tires, if that helps.
Old 07-11-2016, 01:53 PM
BreezyTL's Avatar
Received 1,041 Likes on 773 Posts
no poke, should be close to flush if not tucked a little. Correct me if I am wrong
Old 07-11-2016, 02:17 PM
From the research I've done, stock rims with a 15mm spacer are flush in the front. It's entirely possible my research is wrong, but The rims I'm looking at stick out 20mm more than stock, which is why I'm concerned about poke.
Old 07-11-2016, 02:18 PM
Received 16,267 Likes on 11,974 Posts
worried about 5mm?
Old 07-11-2016, 02:24 PM
BreezyTL's Avatar
Old 07-13-2016, 02:06 PM
UA6MT
numairh's Avatar
It'll sit like this except higher.
Oh Sickest TL (07-13-2016)
Old 07-13-2016, 07:17 PM
Andrew
VisualEchos's Avatar
When I bolted on my 9.5 +40 @ stock height I was poking about 5mm in the front (rear was perfectly flush), and you'll be 2.7mm less outboard than I was, so It'll be super close. If your car has a tad bit more camber in the front than mine did (every car is different), or if your struts are a little bit more worn out then you'll be perfect. With a set-up this flush, it's all going to be about your tires.
Old 07-14-2016, 05:07 PM
Thank you all so much for your help! From what you guys have said It looks like the SSR rims will give me the flush look I'm going for. I'm planning on running stock tires, and the rims are 1/2in. wider, so everything will hopefully be perfectly flush!
Old 07-14-2016, 05:37 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
You should really consider 18s though.
Old 07-14-2016, 07:23 PM
sockr1's Avatar
Received 1,160 Likes on 909 Posts
^^ agreed. 17s look ok on the TL, but 18s look GREAT! if you're going to get new wheels, might as well get 18s. makes the car look so much better
Old 07-15-2016, 07:38 AM
I agree that 18's and 19's look a whole lot better. The issue is I'm on a really tight budget, so I was planning on using my stock tires since they're pretty much brand new. If I got bigger rims and tires I'd be spending at least $1,000
Old 07-15-2016, 07:56 AM
so then save! keep using the stock wheels.
you're stock height any way
Old 07-15-2016, 08:53 AM
The reason I was looking for a second set of rims is I'm going to be getting winter tires soon, since a buddy of mine (who has a TL) said my car will be terrible in the snow. So I'm already spending a chunk of change on the tires, and I wanted to have the new rims before winter. I don't know if I have the patience to save for 18's/19's lol
Old 07-15-2016, 11:47 AM
Andrew
Your car will not be terrible in the snow if you set it up right. Tires is the biggest part of Winter driving, so get a great set of 225 series 17" dedicated Winter tires and you'll be fine.
Old 07-15-2016, 12:59 PM
BreezyTL's Avatar
GG what state are you in? I agree with VisualEchos, tires make a world of difference in the snow!
Old 07-15-2016, 06:54 PM
I live in maine so we get quite a bit of snow. I know the stock tires are 235/45/17, so is there any advantage of different sizes?
Old 07-15-2016, 09:58 PM
BreezyTL's Avatar
thinner the tire the better luck i had! Easier to cut thru snow.
Old 07-17-2016, 07:11 AM
Andrew
This is correct, the contact patch is longer front-to-back, which produces more forward-motion grip. A 235 will be nearly identical on a TL in most instances, but if heavy snow is a concern, the skinnier the tire, the better the grip, just look at Winter Rally tires for proof.
Old 07-18-2016, 08:50 AM
BreezyTL's Avatar
toss 4 spares on and call it a day!
bakaryu18
01-14-2017 11:59 PM
kuzdu
5G TLX Performance Parts & Modifications
20
01-06-2017 02:31 PM
Modassir
11-17-2016 12:20 AM
Dylan Johnson
07-12-2016 11:49 AM
Quick Reply: 17x8.5 +30 on stock height
