16" over Brembos???
16" over Brembos???
I'm looking to get some snow tires on the TL and I was just wondering if there are ANY 16 inch wheels that can fit over the '04 6mt Brembos on the market???
Thanks for the help.
basically it's about the design of the back of the spokes. real japanese wheel mfrs usually include a spec for caliper clearance. they call it the disk type...high, medium, low, super low.
all you have to do is to take off a wheel and measure the following
- the distance between the hub/rotor to the outside plane of the caliper
- the diameter from the hub to the point on the caliper with it sticks out the most
with these two values in hand, you should be able to figure out what works.
courtesy of stoptech
Thanks StanMan.
That's a good pic, and a good idea with the little carboard cutout. Hmm... that looks like there's gonna be footwork involved, running around town with the little carboard thingy. It's difficult to shop for wheels online because of the brake clearance issue, not too many spec sheets specify enough data.
jmoney2001
09-11-2015 12:07 PM
