08 TL wheels question
Old Jan 14, 2019 | 12:17 AM
Geothe3rd's Avatar
Whats going on guys. I just purchased a blk on blk 08 acura tl type s with 55,596 miles on it. Its clean inside and out. I just wanted to introduce myself, names G. And I have a question as far as rims are concerned. I have the factory 17 waffles on there, but I found some blk graphite 18 inch x 11 specs, with the tire at 285 30z 18r. Is that to wide of a tire to put on my car? Its a concaved rim.
Old Jan 14, 2019 | 09:00 AM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum.
Old Jan 14, 2019 | 09:06 AM
Why not test fit them???
It sounds like a used set, with tire. Pull up and test fit.
Because, there are simply too many variables to say " yes, these will fit... Or no, they won't."
For example, if not lowered, Maybe they'll fit with some modifications to the fender.... But without you seeing where they touch, your guess is as good as a blind person.
i will say that people have used sets as aggressive as this, people have gotten these wide ass wheels and tires to fit, with modifications to the fender and adding camber
Old Jan 14, 2019 | 09:45 AM
horseshoez's Avatar
Latent car nut
I'm thinking the odds of the wheels A) clearing the Brembo brakes are fairly slim, and B) the tires and wheels fitting properly inside the wheel wells and not grinding away at body work when the steering wheel is turned and/or when hitting bumps is even slimmer.
Old Jan 14, 2019 | 10:00 AM
thus why a test fit is needed to physically show the OP the limitations....
you can make anything fit with time and money. and a big fuckin' hammer
Old Jan 14, 2019 | 11:31 AM
Ehh, nothing a grinder can't take care of
Old Jan 14, 2019 | 11:34 AM
Midnight Mystery's Avatar
Null and proud of it
Justin.
285, eh? Grip for days.
ThatGuy2018
3G RLX Problems & Fixes
Feb 20, 2020 07:47 PM
Matt Lumpkins
Jan 29, 2019 03:00 PM
mattcl-s
Dec 7, 2018 01:20 PM
Khang.V
Dec 1, 2018 06:03 PM
