06 6MT with M/T ASPEC kit - is the rear lower?
Does the M/T ASPEC suspension kit lower an '06 M/T car evenly, or does the rear sit a tad lower?
Sorry to ask the obvious..but I searched and couldn't find the answer. I know that the M/T kit rakes the A/T car nicely, and the A/T kit makes the 6MT car sit way high in the front. I'm real picky with stance (it has to be perfectly even, or lower in the front) Thanks!!!!
I have the 6MT A-Spec on my Automatic. The back is slightly lower than the front now after 1 year of driving. The back has gotten a little lower over time. I'm guessing the front will still be slightly taller looking in front using 6MT A-spec on 6MT, but not as bad as Auto A-Spec on Auto TL models.
Hey man, love the Buicks
Is your TL a 6MT? For some reason, I cant find a 6MT TL with M/T ASPEC suspension here on AZine. I must fail at search, or something.
Sorry! I thought the title was 6mt a-spec on a 5at TL. In that case, the rear would sit the same and the front will be very slightly higher than mine. Sometimes it seems like there's more variance from kit to kit than from 6mt to 5at kit.
05 NBP 6 MT
I have an 05 6MT with the 07-08 MT A spec suspension...it sits very close to even (maybe even lower in front) rockin the 265/35s after 1500 miles. Will try to get some pics up in the next few days.
OK, so its confirmed....no ass sag I did a set of Pilot Psort AS Plus, did road force balancing and aligned per ASPEC specs....and it rides like it never has. At an indicated 140mph I had no vibration.
ASPEC 2004-2004 6MT kit on 2006 6MT car.
Looks perfect. I had to put my front Konis to the low position to get that stance.
The picture of your car is perfect! If I understand correct, you had a stock setup and all you did was install the apsec suspension kit to get that look?
Finally , does anyone know if I'll get similar results with a 2005 6MT?
thanks!
3G TL/2G MDX Owner
Sorry to revive this thread, but this is exactly what I'm looking for! Only difference is i've got an 05 6MT. Reading through the posts, its hard to figure out which suspension (part #) you got. Was it the 08W60-SEP-401A, 08W60-SEP-401B or 08W60-401C. In the quoted post, you also mentioned "ASPEC 2004-2004." Did you mean 2004 - 2006? If so, do you know what part number it is?
thanks!
thanks!
this is for the 04-06 aspec suspension for MT
mine is sitting in the box waiting for install in a few weeks. i have 05 MT.
as for the OP, my stock suspension sits with the front slightly higher than the rear. hope the aspec kit has the car sit the way it looks in the pics on the post. i like.
1fatcrxnem1
22
06-01-2018 01:23 AM
Joseph Stansbury
34
12-04-2015 01:57 PM
handsom-hustla
11-13-2015 05:04 PM
09-04-2015 08:03 AM
