Yet another 3x3 question
Old Sep 4, 2012 | 09:02 AM
adsoldschool's Avatar
I'd rather be golfing
I was recently doing my 2nd of the 3x3 trans fluid xchange... lowered the car to ground level to get the last of the fluid out. Once the drips stopped, I leaned in on the top of the engine to do some other inspection, and when I did, a little more fluid came out of the drain hole. Got me to thinking... if I now raised the back of the car, would I get more than 3 quarts out of the drain, and if so and knowing how much, would that be a more effective drain process? Anyone else done this to get more out of the torque converter?
Old Sep 4, 2012 | 09:45 AM
Acura-OC's Avatar
When I did first change, I did it on a hot engine/transmission and I got almost 4 quarts out of transmission using ramps (raised front only). Second time I did it on a cold transmission and I got 3 quarts only. Maybe there is some kind of thermostat that shouts off radiator. But I do not think that lowering front will give you much advantage if anything I'd think that raising drivers side only would be most beneficial. I do not think you need to go through all this trouble even with 3 quarts drained every time. I didn't feel much difference after first change but after second 3 quarts it feels like I am driving a new car. I honestly didn't think it will do much and thought that some of the people will do anything just to spend more time with their car. I was wrong.
Old Sep 4, 2012 | 11:05 AM
Turbonut's Avatar
Usually if only the front end raised, the drain won't yield 3 quarts, it will be less.
Old Sep 4, 2012 | 02:18 PM
07NBPTL-S's Avatar
The car should be level when draining your transmission fluid.
Old Sep 5, 2012 | 06:06 PM
dzionny_dzionassi's Avatar
and why do we need to level the car?
TypeS860
Jan 10, 2026 11:11 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
