WOW...im such a DI*K
this little bolt snapped on the pcv valve. my torque wrench must me broken if this thing snapped. i have no idea what to do now. ill try an extractor but its in such a bad spot that i cant even see in there. can u drive with no pcv valve or will you be shooting oil and junk everywhere?
number 10 snapped
number 10 snapped
thanks KN. for the time being i used a zip tie through the bolt hole on the pcv valve and wrapped it around the oil dipstick. its actually very snug.
i drove a few places like that and had no problems. im going to wait for the fuel injectors to come in before i take this thing apart. no need to do it twice
i used a torque wrench because i always like to have things within spec..im anal like that
id love to use and extractor but i cant get a drill in there to drill a hole first. i tried a right angle drill but it was still too big. if i had one of those really small right angle air drills it would work
Believe it or not, we use calibrated zip tie guns at work. They pull the tie tight and clip then end flush so as to not leave a sharp plastic tail. HAHA. I don't use them unless an inspector requires it.
