Wipers and washer stopped working?
Old Jul 7, 2017 | 06:35 PM
Mcdoogle1975's Avatar
What else would cause my wipers and washer to stop working at the same time? Fuses are all good checked and double checked.... removed wiper assembly and bench tested...works as it should. Check the pin out on the harness that plugs into the motor and no power where there is supposed to be power?
Old Jul 8, 2017 | 03:46 PM
Crashmaster's Avatar
Have you checked the recalls?
NHTSA Campaign Number: 08V092000
Manufacturer HONDA (AMERICAN HONDA MOTOR CO.)
Components VISIBILITY
Potential Number of Units Affected 129,600
Summary
HONDA IS RECALLING 129,600 MY 2004-2005 ACURA TL VEHICLES. IF WATER ENTERS THE WINDSHIELD WIPER MOTOR BREATHER PORT, WHICH IS DESIGNED TO ALLOW THE MOTOR TO VENT WARM AIR DURING NORMAL OPERATION, IT CAN RESULT IN CORROSION INSIDE THE MOTOR HOUSING. THIS COULD CAUSE A FAILURE OF THE ELECTRICAL CIRCUIT BREAKER INSIDE THE MOTOR HOUSING.
Remedy
DEALERS WILL INSPECT THE WINDSHIELD WIPER MOTOR FOR SIGNS OF CORROSION. IF NO SIGNS OF CORROSION ARE PRESENT, A SNORKEL TUBE WILL BE ADDED TO THE WIPER MOTOR BREATHER PORT TO PREVENT WATER FROM ENTERING THE WIPER MOTOR HOUSING AND FOAM TAPE WILL BE INSTALLED ON THE COWL ABOVE THE WIPER MOTOR TO DIRECT WATER AWAY FROM THE WIPER MOTOR. IF SIGNS OF CORROSION DAMAGE ARE OBSERVED ON THE WIPER MOTOR, THE MOTOR WILL BE REPLACED, AND THE BREATHER TUBE AND FOAM TAPE WILL ALSO BE INSTALLED TO PREVENT WATER INTRUSION ON THE NEW WIPER MOTOR. THE RECALL BEGAN ON APRIL 28, 2008. OWNERS MAY CONTACT ACURA AT 1-800-382-2238.
Old Jul 8, 2017 | 05:07 PM
nfnsquared's Avatar
OP, replace the fuse even if it "looks" good.
And you are aware that fuse 20 is supposed to be 10A now? (04-05 TL)
http://techinfo.honda.com/Rjanisis/pubs/SB/B05-033.PDF
