Winshield Wiper Fluid Not Coming Out...
....and I'm damn confused. This has never happened to me before. I refilled when it stopped and have tried a bunch to get my wiper fluid to come out, but to no avail. I'd consult the manual, but (long story), it's not currently in my posession.
Any help for a home fix before I take it in would be greatly appreciated, especially before hitting those Chicago streets!
Quick question. When you start the car does your Auto Dimlight on your R.view mirror light up? Or does one of your side mirrors swivel when you throw the car in reverse? If that's the case it's a blown fuse.
Also, if everything is working properly feel the washer fluid lines and check out the nozzles where they spray from. If the lines are frozen they just need to be warmed and if it's just the nozzles just use a needle head to poke open the holes
Been there ......... if it's like 10 or lower out and you're driving down the highway for an exented period of time the fluid will freeze. This is with normal fluid that supposedly holds to - 20 degrees. I guess the wind chill does that. I had that happen and the only thing I could do is grab a jug from a gas station and stop every so often to dump some on the car........ a tad annoying ..... Later after the car sat for a while the fluid thawed out and it started working again. However, i swear someone from canada said that canadian tls have heated washer fluid. If that's acutally true, doing that mod might help.
Wax gets in the sprayer holes so poke them with the needle
Get a small piece of reflectex from hardware store and suround the washer bottle with it.
That should keep fluid warmer. Wind chill freezes fluid- thats something the engineers never thought of.
Anyone got a safe product to use for those of us where they dont sell -30 fluid, and we still like to visit the cold and snow??
NICE.
Blown fuse it is! I totally should have thought of this. As usual, this forum rules. Thanks for all the good ideas.
In response to the other stuff, yeah I use the good stuff. It's garaged, and while not heated, is certainly well above freezing at the moment. I did the hot water thing too, to no avail.
Completely forgot about the fuse thing. Glad I'm a regular here!
Just got the new fuse. Interestingly enough, it was #20 on the panel inside the cabin that was blown but there was no little pincher thingy to pull them out with. A nice guy in the store actually let me use the one from his car (along with his flashlight) to make the exchange.
Long story short -- do any of your TLs have the fuse grabber-thingy in the cabin fusebox? If not, where the hell is it located for future reference?
Originally Posted by ..Mark..
Are the mirrors supposed to go down in the 6 speeds as well?
So washer fluid that's supposed to be good to -20 won't freeze at -19, regardless of the wind speed.
Originally Posted by ZeeJM
Umm... While wind can increase the rate at which a liquid cools, the liquid will never get colder than the temperature of the air that's cooling it. In other words, there's no such thing as "Wind Chill" for inanimate objects.
12. Does windchill only apply to people and animals?
Yes. The only effect windchill has on inanimate objects, such as car radiators and water pipes, is to more quickly cool the object to cool to the current air temperature. Object will NOT cool below the actual air temperature. For example, if the temperature outside is -5 degrees Fahrenheit and the windchill temperature is -31 degrees Fahrenheit, then your car's radiator will not drop lower than -5 degrees F.
Originally Posted by fish008
Yes they will tilt down in the 6 speed too (works in mine). You just need to select the right or left mirror and that mirror will tilt down when you put the car in reverse. If you're in the middle neither will tilt down.
Never frooze on me..
2007 TL
I'm having the same problem with my washer fluid pump. My fuse #20 in the cabin (down by the hood releae latch mechanism) checks out good and there's power at the fuse socket. Is the another fuse to check.
Also, I cannot hear the pump when pulling the stalk back.
My auto dim light on my r view does light up when the car is started. I thought it was supposed to. How is that tied to the fuse?
Any suggestions or test methods?
Thanks,
Doug
Thanks,
Doug
Fuse #20 controls the washer pump, auto-dim mirror, and power mirror controls.
If the light in the mirror is on, it's not the fuse. Either you have a loose connection, the pump is fried, or the switch is bad...
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
