Window Problem?
Old 07-07-2009 | 01:32 PM
TL|GTX's Avatar
A Black TL
Window Problem?
Well yesterday while driving down the road, my friend tried putting the passenger window down, but it wouldn't go down then i tried doing it from the main controls on my side, it wouldn't go down. And the i checked if the windows were unlocked and yes they were. Then i stopped and told her to open and then slam the door, and she did then it worked kinda, got stuck halfway but then slowly went up. Then the problem went way.
Old 07-07-2009 | 05:34 PM
zsameer's Avatar
I had the exact same issue. The passenger side window wont roll down from the mail or the control on the passenger side. and then it just started working after a few tries. havent had that problem again. Maybe it was just stuck.
Old 07-07-2009 | 06:55 PM
csmeance's Avatar
The window run channels are probably dirty, have acura lube them and clean them...
Old 07-07-2009 | 11:45 PM
TL|GTX's Avatar
A Black TL
i love u csmeance thx
Old 07-08-2009 | 02:18 PM
csmeance's Avatar
:theghey:
just kidding
Old 07-08-2009 | 03:29 PM
LoveMyTL-S's Avatar
You may need to grease the Regulator. Use Shin-Etsu grease. P/N 08798-9013.
Old 07-08-2009 | 11:17 PM
cdp5095's Avatar
04 tl
im having the same exact problem, on my rear view mirror.. i check the fuse but its good. tomorrow ima take the door panel off and check if something is loose.
Old 07-09-2009 | 11:41 PM
Souljah's Avatar
Former Whiner
Windows don't go up
I assume it's the same thing if my window does not roll up?
Seems as if there is a sensor...
it starts to go up then shoots back down?
Old 07-10-2009 | 01:15 AM
TL|GTX's Avatar
A Black TL
Well i called the dealer, and they said i gotta pay like 20$ for them 2 do this omg, they always want money 2 do shit.
Old 07-10-2009 | 01:50 AM
csmeance's Avatar
it should be covered under warranty, it's not a maintenance item. There's a TSB on the issue too.
SidhuSaaB
05-30-2020 01:40 AM
udelslayer
1G RDX Problems & Fixes
05-06-2016 01:27 PM
tristann616
1/2G MDX (2001-2013)
09-23-2015 12:40 AM
wcimo
09-21-2015 11:55 AM
ahsm
09-09-2015 09:35 AM
Quick Reply: Window Problem?
