What would you do next.. AC
2006 Acura TL 62K miles. AC None functioning, with Florida heat .Power confirmed to Compressor However doesn't engage when AC turned on. Compressor coil ( Stator unit) was found defective, and changed (dealer OEM). AC functioned for 1 week and now compressor not engaging again. Power confirmed to compressor. All fuses intact. Worried about actually buying a complete new compressor if I will encounter the same problem.
iWhine S/C 6MT TL
Time for a compressor unless your there is low freon in the system.
Dogmatic Dinosaur
If power is getting to the compressor, then the pressure switches are reading OK. Probably time for a new compressor clutch.
Before you do this, try a different positive wire - maybe straight from the battery. Also, make sure that the clutch is grounded OK.
I'm gonna look into these to. Will provide feed back. Thank you.
CivicB18B1
05-13-2010 05:01 AM
xtremex626
2G TL Photograph Gallery
20
12-08-2009 03:17 AM
