What type of EGR valve do we have?
So I pulled the EGR valve off my TL tonight to clean it due to a P0404 code. Does any one know if the pindle on the EGR valve is spring loaded? I tried pushing in the pindle with a screwdriver in order to clean the carbon build-up but the pindle won't go in.
2007 TL
Can you post a picture of your egr valve in the engine? I'm trying to clean mine too and I don't know where it is. Then maybe I can help you with your problem.
https://acurazine.com/forums/3g-tl-problems-fixes-114/119-diy-egr-replacement-770698/
Take the plastic cover off the engine. The EGR valve is on the right side mounted down where the radiator hose goes into the engine. There is a gray plug going into the top of it held in place by 2 nuts on the base.
actually, i kinda figured out the cleaning process for the EGR valve on our cars. Instead of the pindle pushing in, the pindle pulls out of the valve. So, I just took a flathead screwdriver and pry the pindle out a little while I sprayed throttle body cleaner all around it.
worth while?
I have 120k on mine and thinking of cleaning it along with my timing belt job.
sockr1
10-01-2015 01:31 AM
