What transmission fluid should I use?
I'm sure this has been answered before but the search function doesn't seem to be working for me.
2004 Acura TL 95k miles.
I had the timing belt/water pump/etc service done at about 90k miles and while it was at the acura shop they suggested replacing the tranny fluid. I said go ahead. They suggested that I change it again at my next oil change which is due right now.
I am fully capable of doing this myself. I know that you only get about 3 quarts out which is why you are suppose to do it 3x.
My question is what kind of tranny fluid should I use? I heard that the Acura tranny fluid is junk and not to use it? Is this true? Can I just use something like Amsoil synthetic or should I use something else?
I'm assuming that the acura place used the acura fluid. Can they be mixed with something different if I'm not using the acura fluid?
Thanks for any information you have !
Honda/Acura has a new fluid..way better than the old stuff and it works!....I've used it when I had my auto TL and shifted smoother instantly....I would NOT put anything else in my tranny if I were u
^ I also use the new Honda ATF in my wife's Pilot (2003), it's only used Honda ATF and is at 210K miles with original AT never had a problem.
Others on this forum have used other ATF's to good success on their postings.
SidhuSaaB
May 30, 2020 12:40 AM
