What is this thing called?
They are number 6 and 7 on the diagram. REAR LOWER ARM for 2006 Acura TL
I had to replace both of them last month on my car after 242k miles. I heard a knocking noise & the mechanic lifted it up.
The originals are made with cheap plastic, but replacements from Autozone or Advance are all metal.
Was pretty cheap to replace.
Normally that would be a quick and easy fix but you have some rust on the bolts. I would try to remove the part first. If you have success then order the replacement. If you fail then take it somewhere.
kliqzero
Jan 12, 2016 12:06 PM
