what is this snapped piece (please help)
Old 03-20-2017 | 09:50 PM
FreshPrinceXO's Avatar
Post what is this snapped piece (please help)
recently noticed this looks like a snapped piece ? I'm thinking it's my sway bar links? not really sure . sorry for the noon question . any help would be appreciated.
Old 03-20-2017 | 09:55 PM
That would be your front sway bar end link
FreshPrinceXO (03-20-2017)
Old 03-20-2017 | 10:00 PM
thank you !
Old 03-20-2017 | 10:15 PM
truonghthe's Avatar
sway bar end link, its better off if you cut the bolt since all it does is just turn around and around.
Old 03-21-2017 | 08:14 AM
nfnsquared's Avatar
^^^^huh? the bolt end has a hex cutout. Use a 5mm allen wrench in the end of the bolt and IIRC a 14mm wrench on the nut. I'd soak the nut/bolt with PB or Deep Creap for an hour prior to removal.
Old 03-21-2017 | 11:15 AM
BreezyTL's Avatar
Agree with this, soak the hell out of it. Those are a pain even with the 5mm allen. GL!
Old 03-21-2017 | 01:52 PM
WDPanda's Avatar
You got some aftermarket axles there. Any vibrations on acceleration?
Old 03-21-2017 | 03:39 PM
TacoBello's Avatar
I would just cut it off too. So much easier than dealing with rust. Yes there is a hexagonal hole on top, but I've seen people strip those like they're made of hot butter.
Old 03-21-2017 | 05:41 PM
truonghthe's Avatar
My old accord rusted so bad that it won't come out so I end up cutting the bolt off.
