What Could Be Causing these Problems?
Old Jul 16, 2015 | 12:24 AM
CenturionTL's Avatar
I ran a code on my vehicle and these issues came up.
61-1 Battery Voltage Malfunction
86-1 Controller Area Network Relation Malfunction
Thanks.
Old Jul 16, 2015 | 12:38 AM
polish_pat's Avatar
Thanks.
A part from the code, whats the problem? Does it start?
Maybe starter issue, maybe fuse, maybe some bad wiring, maybe bad battery or bad switch somewhere...again, it all depends on the actual symptoms.
Old Jul 19, 2015 | 10:32 PM
Its the battery connectors / wiring. Could that be throwing 86-1 Controller Area Network Relation Malfunction?
Old Jul 22, 2015 | 09:50 PM
My car stopped working while I was driving. Its the alternator.
I have following codes.
83-1 Engine Control Module ECM, Power Control Module (PCM) Relation Malfunction.
Are these due to the alternator or are they fried?
Old Jul 22, 2015 | 11:15 PM
What goes out when the alternator fails?
I have a burning smell coming from the engine. Is it the serpentine belt?
Old Jul 22, 2015 | 11:17 PM
I also have a whining noise coming from the throttle body area.
Old Jul 23, 2015 | 03:01 AM
polish_pat's Avatar
Problem overload. Your car is trying to tell you its sick. Take it in before it dies of terminal cancer
Old Jul 23, 2015 | 03:21 AM
My battery cables were faulty, previous owner replaced the end connectors with auto zone connectors, vehicle was not getting full power before, when I replaced the cables, I received full power.
That's why these codes were appearing:
86-1 Controller Area Network Relation Malfunction (unsure)
Since my 05 TL is receiving full power now, the alternator fried, also in part because previous owner had a sound system in the vehicle.
The other codes:
is due in part because of alternator? Or is my ECU damaged?
Old Jul 23, 2015 | 03:30 AM
My passenger headlight went out at the same time.
Old Jul 23, 2015 | 08:42 PM
polish_pat's Avatar
I was leaning towards cables too. Good to know you can confirm that.
As for the alternator, i bet the guy didn't install a power capacitor to absorb the excess electricity, which you're lucky if it only fried your alternator.
I Don't think its the ECU as there should be a failsafe against electrical drawbacks. Your alternator and headlight, those two are expose. It's crazy how a 40$ piece of equipment can save you thousands in repairs...and most people dont even put one.
SidhuSaaB
May 30, 2020 12:40 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
